EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Low budget tool making. (https://ecomodder.com/forum/showthread.php/low-budget-tool-making-30091.html)
u.steinlechner 09-26-2014 04:40 AM
Hello,
for fiber composite parts it is important to make molding tools.
CNC molding tools are expensive so I decided to make the tool at the workbench.
You need a 3D geometry and cut-curves.
For symmetric molding tools, I used wooden templates to cut with a hot wire.
https://www.youtube.com/watch?v=iNs6...1PLQ1PFOI_3HGA
https://farm9.staticflickr.com/8323/...027883_z_d.jpg
Then I cut styro plates.
Following pictures and the video gives yo a overview, how to make the tool.
https://farm9.staticflickr.com/8047/...7a790e_z_d.jpg
https://farm9.staticflickr.com/8336/...a60310_z_d.jpg
https://farm9.staticflickr.com/8475/...537c67_z_d.jpg
https://farm9.staticflickr.com/8193/...c3686a_z_d.jpg
Kind regards
Ulrich
freebeard 09-26-2014 08:39 PM
8 Thanks and no comments?
Have you seen http://ecomodder.com/forum/showthrea...eat-22529.html? One of our members is (slowly) building a whole car that way.
u.steinlechner 09-27-2014 05:22 AM
It will work
Yes, I saw this and I think it will work.
Ulrich
u.steinlechner 09-27-2014 05:32 AM
Details
In this photo gallery you will find some more details.
Xanon Bionic Electric Vehicle - Xanon-X3 Werkzeuge Formenbau - Werkzeuge und Formenbau
The inner airbox and expansion chamber were made by lost tools.
http://www.xanon.de/images/phocagall...l__MG_1524.jpg
RustyLugNut 09-27-2014 12:06 PM
Thanks for the pictures and links. Nice work.
Madact 10-03-2014 04:14 AM
I've done something similar in the past, but skipping the 'wooden template' step by simply using a projector to project sections onto the material (calibrated by use of a ruler matched to the projected image), then tracing with a texta.
Initially doing the cutting with an electric jigsaw, but that created a *lot* of nuisance dust - you ain't seen nuisance dust 'till you've seen polystyrene nuisance dust, the stuff electro-sticks to *everything* :p . Turns out a snap-off blade utility knife with the blade fully extended, and held at a fairly low angle to 'drag' through the polystyrene, works much better and produces a nice clean cut (and doesn't produce the nasty gasses that a hotwire does).
For what I was doing I didn't need the precision you get from u.steinlechner's more traditional method, but I reckon you could get the best of both worlds (precision and even less cost) by printing the profiles on large format paper at an office supply store, and using a utility knife for the cuts.
I must say though, the hot wire produces some very nice circular holes :thumbup:
mcrews 10-03-2014 11:43 AM
here's a comment: "WOW :eek:....no really WOW! :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :D
freebeard 10-03-2014 03:27 PM
http://ecomodder.com/forum/member-fr...e6263-tool.jpg
An vintage tool from the 60s. It was US$1.99 at a second hand store, and uses 2 D-cells.
Try a knife blade instead of a saw blade in the jiggler saw. It works great on corrugated cardboard, and should do well on stryofoam.
Xist 10-04-2014 12:48 AM
I really like the construction methods of carBEN. Too bad nature conspired against it! I am glad that was not worse!
I bought the nichrome wire to make a wire cutter, but connecting it to my battery charger did not do anything, although I have charged batteries in two different Civics with it.
aerohead 10-04-2014 12:47 PM
cutter
The late Bob Parsons had a 'VARIAC',variable-voltage,DC power supply that he used for hot-wiring.It's like a larger version of a scale model train transformer.
Once you dial in an acceptable output,you're golden.
Alexander Sport Air used them at Oshkosh during their annual Fly In workshops.
I found one in Dallas at the monthly electronics swap meet for $35.
