Low drag shapes and lift
Here's a topic where complete rubbish has (very unfortunately) been disseminated on this forum over many years.
And what's that? It's that coupe (curved fastback) shapes have low lift - but they don't. Here's a good comparison. https://www.youtube.com/watch?v=PoEGHtZB8TA So... typically, these shapes have low drag but high lift! One very important reason that car manufacturers add rear spoilers (etc) to most low drag shapes. |
coupe
The image you've chosen for a 'fastback' isn't actually a fastback, as a true fastback has an unbroken roof contour. What's shown would constitute what is currently referred to as a 'Sportback', as Audi and Mercedes-Benz refer to them. Also, the term 'fastback' could be taken as a true, streamlined contour, as with the 1922 Jaray Cd 0.13 pumpkin seed, or a 'pseudo-Jaray' contour, high-drag contour, as with the original Porsche Cd 0.40, 911/ 912. Also, also, streamlined fastbacks, as the Nissan LEAF, will not generate as much rear axle lift as Mercedes-Benz CLA 250, or Tesla Model S notchbacks. Any blanket comment about 'fastbacks' and propensity for rear lift would fail in light of available evidence. |
https://cdn.motor1.com/images/mgl/kg...issan-leaf.jpg ...and this a notchback? https://cdn.motor1.com/images/mgl/7Y...l-s-update.jpg The Leaf's low lift is probably due to the fact that it is quite clearly a squareback, and squarebacks--as Hucho and many, many other authors note--typically develop less lift than fastbacks or notchbacks. |
I seem to remember many years ago an EM member being flamed and banned for suggesting that “template” shaped cars could get light and could be dangerous at high speeds on dirt roads. Does anyone recall this video of an Insight crashing at 190 mph at El Mirage? It sure looks to me like the back end got light and tried to pass the front despite this being front wheel drive with the weight of the motor and trans ahead of the front wheels.
https://youtu.be/hbNlR-fMlOw |
in what world
* Aerodynamically, a fastback is an uninterrupted contour which is streamlined, and leads to low drag. Such is that on the LEAF. The LEAF roofline, however, has been cut short, losing additional pressure regain, losing additional drag reduction potential from the roof truncation, and opportunity for even lower rear lift. If the LEAF roof wasn't cut short, it would be a 'Kammback.' And a 'Kammback' is simply a truncated long-tail ( lang-heck ). In spite of the roof chop on the 'Drag Queens' LEAF, it had lower rear lift than the Tesla Model S. -------------------------------------------------------------------------------------- * As to the Tesla Model S, I would describe it as a fastback-type form, perhaps compromised for rear visibility, with a spoiler incorporated into the contour to create the short deck, allowing for flow reattachment, and perhaps an alcove, from which an active rear pop-up spoiler might emerge. As on the original Model X. |
It's a fascinating world where reality can be altered to fit belief. |
Crash of the HONDATA
Like the Racing Beat' Mazda RX-7, the HONDATA lost traction, yawed, became a crude wing section, then lifted off, initiating the series of barrel rolls. If speed limits are to be raised to 190-mph, then we have a problem. At 135-mph, Spirit generated negative 30-pounds at the front axle, and positive 22-pounds on the rear axle. On a truck which weighed 4200-pounds. With a 'template' body. I don't believe it to be an issue. The 1992 Corvette LT1, which was two cars ahead of me at DARKO went airborne for the same reason as HONDATA and Racing Beat. The car lifted around eleven feet vertically, landing on its; roof at 220-mph. Guess we should ban Corvettes. The owner was given the recommendation to install air fences. Which never happened. |
definitions
If that's the qualifier, then the LEAF is a roof-truncated fastback. Adding the 'elongation' to achieve the lower drag would visually drive the message home. Like the 1978 Daimler-Benz, Mercedes-Benz, C-111, III, in three flavors: Cd 0.237 to Cd 0.178. Depending on length.:) |
1. You have Hucho's 2nd-Edition. You know that he basically said that 'fastbacks' are the only real path to low drag. 2. If that's the qualifier, then the LEAF is a roof-truncated fastback. Same logic as: 1. Dogs have four legs. 2. This animal (a cat) has four legs, therefore it is really a dog. |
logic
2) The solution was to extend the roofline, following an extrapolation of the initial contour, to the very end of the vehicle, filling in the turbulent void. 3) This is the reason your Insight has the roofline that it has. If it were mutilated as with the LEAF, you'd experience increased drag and lift. 4) If carried to it's conclusion, the LEAF becomes a pumpkin seed, just as Kamm, Lay, and Jaray arrived at. True 'fastbacks.' |
