LRR tires currently available?
I just found this new tire in the Bridgestone Ecopia series:
Product Details: Ecopia EP422 I also learned recently from a tire shop about a Kumho brand "Ecowing" series. Anyone know a good place to find the rolling resistance coefficient ratings for these and other tires? |
Although they don't list the coefficients directly, Tire Rack allows you to filter for only LRR tires after you have selected your tire size.
Thanks for this response instarx. I have been to the tire rack site, but the problem is that there are LRR tires and then there are other LRR tires, as an older listing of rolling resistance coefficients on this forum shows. I'm hoping to learn where to find such data for more recently marketed tires, such as the Bridgestone Ecopia ep422. That info should be available to the public somewhere, eh?
i think Consumer Reports is due (or overdue) to rate all the LRR tires so we can see an unbiased evaluation.
The best thing you can do is google about the tire you want and hope someone has tested them against some other tires. |
yeah, i wish I knew whether to buy the Bridgestone D381's, the Nokian eNtyre, the Cooper GFE, or the Kumho KR22's.
Summer tires 2011 finnish (TM magazine) LRR results for size: 205/55R16:
Michelin was the best and those % number are the difference in fuel consumption. So the worst tire consumes 6,8% more fuel than the best. MIchelin energy saver 0% Goodyear efficientgrip 0.1% bf goodrich g-grip 0,9% Nokian hakka green 0.9% barum bravuris 2 1,5% continental contipremiuncontact 2 1,7% Vredestein sprottrac 3 2,1% Pirelli cinturato p7 2,8% Sunny sn3630 3,9% Hankook ventus prime 2 4,0% Bridgestone turanza er 300 ecopia 4,4% Linglong green max 4,5% Nokian Hakka V 4,7% Dunlop sp sport fastresponse 6,2% Sava intense hp 6,8% If you like to take a look at the full test it can dowloaded here in finnish: Vertailu - Kesarenkaat 2011.pdf Overall winner of that test was continental contipremiuncontact 2. |
the odder thing yet, is that the premiumcontact2 in the USA is not even rated as a LRR tire. |
That test was not for LRR tires but summer 2011 tires overall. One test section is for LRR measurements. Best 4 tires are advertized at least here in europe for LRR tires.
ahh, gotcha. then it's my conclusion the reason why michelin energy savers finished so well in that comparison is because they weren't pitted against other LRR tires.
