EcoModder.com
-   Success Stories (https://ecomodder.com/forum/success-stories.html)
-   -   LRR Viva 2 tire results (https://ecomodder.com/forum/showthread.php/lrr-viva-2-tire-results-9379.html)
RandomFact314 07-24-2009 04:14 PM
Tires Before: (All tires are 185/65/14, even the new ones)
FRONT:
Goodyear integrity (25-35psi) no tread, leak (44max psi)
Goodyear integrity (20-35psi) no tread, rapid leak (44max psi)
REAR:
Radial classic (35psi) no tread
Radial LTE Futura 2000 (35psi) no tread (44max psi)
Tires NOW:
FRONT:
Goodyear Viva 2 (44psi) ~LRR
REAR:
*Rear is same as before*
***And now these are my last 3 results (I'm only showing the last 3 because they are with the same weather, And I removed the one that was all highway)
Before:
30.36
30.53
30.83
After Replacing the front 2 tires:
31.34
SVOboy 07-24-2009 04:16 PM
I demand ABA!
RandomFact314 07-24-2009 05:58 PM
Originally Posted by SVOboy (Post 117507)
I demand ABA!
I don't have the old tires anymore, And I defiantly could not un-mount, mount, un-mount, and remount them over and over anyways.
orange4boy 07-24-2009 06:24 PM
I think he's pulling your rubber leg.
Or perhaps it's a typo. SVOboy demands ABBA?
LRR is the bomb! I bought my new "HRR" before I knew LRR were readily available.
RandomFact314 07-27-2009 01:04 AM
So if I were to just guess (not that I completely think this) they gave me +1mpg, if I changed the 2 back tires to the same tires would I get another 1mpg or would it be less since they are back tires and not doing much?
KJSatz 07-27-2009 01:06 PM
Wild speculation:
The back tires are doing much. They support roughly half of the weight, and there is plenty of rolling resistance generated back there. +1 mpg, perhaps not, but gains? Probably.
Nevyn 07-28-2009 10:02 AM
I agree on the Viva 2's...replaced rears on my Lumina (Deltas w/no tread to Viva 2's) and saw 1.5 MPG.
Give 'em about 1200 miles to 'break in,' and they'll feel less squishy as the releasing compound works out of them.
RandomFact314 08-01-2009 08:19 PM
Oh really?! cool, they seem a little "squishy" during braking but I didn't know what that was.
Nevyn 08-03-2009 07:54 AM
During braking and heavy cornering, I bet - you'll feel more than normal body roll and "sloshing" - as if you are driving on a waterbed.
You can accelerate the "break-in" by wetting them down, giving them a light scrub, and rinsing again, but may as well save the water and just drive 'em.
RandomFact314 08-05-2009 04:48 PM
So why exactly do they do the "squishy" thing? its a chemical in the tire? Explain please
