Making Hypermiling easier with Buttons
http://bp1.blogger.com/_2A3Fl4I3bzo/...0/IMG_0486.jpg
I installed a toggle switch to turn on the radio, a toggle switch to turn on the computer and fuel pump/injection, and a push button starter switch. I used a 40 amp auxillary headlight relay to reduce the current through the computer power switch, the stereo toggle is a 20A switch, and the starter button is a heavy duty one, so no relay was needed there. Here are the switches exposed; the start button is where the cigarette lighter should be. http://bp0.blogger.com/_2A3Fl4I3bzo/...0/IMG_0488.jpg I had a couple of people ask how the wiring is done, and if you could do it differently, so here you go! More details are on my blog. http://bp0.blogger.com/_2A3Fl4I3bzo/...ortWiring1.JPG http://bp2.blogger.com/_2A3Fl4I3bzo/...ortWiring2.JPG |
thats cool, but whats the point?
Yep i got plans for a engine kill switch mounted on the shifter for easy EOC, and may do a start button near the shifter too..
I hopefully won't have to use the start button too often; this little car is super easy to bump-start, and I just replaced the transmission mount to make sure it's ready! |
Another 40A relay with a 5A button was what I was going to try, but O'Reilly's discontinued the line that carried the one I wanted, so I went with the Heavy Duty version - a big brass button. |
The person who had my car before me installed a push button ignition. They were trying to make the civic into a tuner, but did not get very far. I have one toggle switch for the entire electrical system and then a momentary push button for the starter.
The system works well for EOC. I get up to speed and flip the toggle switch to kill the electrical. I then turn the electrical back on to power the odometer. When it is time to start the engine, I just push the starter button. I have no idea how the person wired it, but it seems to work well and I have seen no ill effect in the 4 months I have had the car. |
I would not want to kill the ecu all the time, as modern ecu's have a learning feature, and are probably not as efficient compared to if you have been driving a whole day or two with no interruption to the ecu's memory. Turnin off the engine @ key isn't cutting all the power to the ecu. I used to do that to get rid of check engine lights when I overboosted my srt-4. I would get the WOT power back with a reset, but the car ran ugly on both the streets and the highway for a few minutes everytime. I dont know how you did your mods. However i DO have an injector cutoff that is installed, and who knows if its really making a difference I plan to make it all automatic with vacuum switches that open/close when throttle is released.
