Making a "Kammback" with the Sunroof and Rear Window
Lester has a sunroof and rear window. I was wondering what would happen to the aerodynamics of the truck if I were to open both of them. Does anybody have any idea what that would do or can anybody do one of those airflow diagrams to see how it would work?
Thanks! :thumbup: |
http://images.thecarconnection.com/m...00027914_m.jpg
I think it would hurt the aerodynamics, especially with the sunroof open. Not sure what to think with just a rear window open. Assuming it is the kind that retracts into the door, I guess it starts to look a little like a box cavity back there, but box cavities have to be carefully tuned and their benefit is very small and highly interactive with other aero features, apparently. |
Don't open the back window while driving unless you also have side windows open. You will be sucking your exhaust fumes into the vehicle.
If you want to try it do so on a gravel road, it will be obvious if you are sucking the wake into the cabin by the dust levels well before you get any CO poisoning. I miss my 4Runner. |
open
I'll vote 'don't also.
The lowest pressure outside the vehicle is near the windshield.If you open the sunroof and rear glass,the low pressure above the roof will telegraph through the cabin,bringing air and exhaust fumes forward towards that low pressure as it attempts to equalize the static pressure between the two areas. It not only ruins the airflow,but it poisons you to boot!:( |
STOCK :http://farm6.staticflickr.com/5450/9...1aeeaa77_o.jpg
SUNROOF OPEN / BACK WINDOW OPEN : http://farm8.staticflickr.com/7344/9...9ac7e26f_o.jpg SIDE WINDOWS OPEN / BACK WINDOW OPEN :http://farm6.staticflickr.com/5471/9...7c6540b2_o.jpg |
I had pondered the same thing before on this forum. Thanks for the idea to test it in CFD.
I'll test the coefficient of drag later to see how bad it gets with the windows open.
Actually the flow appears to be moving out of the cabin. Here is a video :
http://www.flickr.com/photos/60376566@N00/9693089745/ I'm multitasking here and getting ahead of myself. |
I will test this later as well. I think it's the fact that my computer is bogged down from having too many things going and it is causing everything to act screwwy. |
