EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   Manual disengage for a centrifugal clutch (https://ecomodder.com/forum/showthread.php/manual-disengage-centrifugal-clutch-7768.html)
The Atomic Ass 04-06-2009 10:19 PM
My Burgman has a centrifugal clutch, and I'm trying to think up a way I can manually disengage it at speed.
I won't have a good idea of what to do until I have the clutch in my hands, but I'd like to know if anyone knows of an easy way to force a centrifugal clutch to disengage while at speed.
dcb 04-06-2009 10:40 PM
I've wondered about that myself. Other options might be to replace it with a manual clutch somehow. Or put a heavy duty freewheel on the rear sprocket maybe.
The Atomic Ass 04-07-2009 09:51 PM
No rear sprocket here.
The engine crankshaft goes into the CVT, the CVT exits into the clutch, and the clutch drops straight into a fixed gear reduction drive which feeds the rear wheel directly. There's no sprockets anywhere.
Ryland 04-07-2009 11:42 PM
A free wheel on the engine or wheel side, either one would work but would be some machining to get it done, your wheel is a side mount wheel on the rear, right? make a free wheel that goes between the wheel and the drive shaft.
The Atomic Ass 04-08-2009 09:38 PM
I'm a day-dream engineer, not a real one. :p
I really can't see a way to make it happen, as the wheel is more like a cars', with 3 lug bolts, and the bit with the lugs is on a splined shaft.
Ryland 04-08-2009 11:21 PM
So what you need is a free wheel that goes between the hub of he wheel and the drive hub, the walk behind tractor compeny BCS makes a free wheel hub retro fit for their tractors so you can turn sharper, it has a wheel bearing in it and a free wheel that protrudes through the hub of the wheel, you just bolt it on before you bolt the wheel on.
The Atomic Ass 04-10-2009 10:38 PM
I honestly can't picture what you're describing. :confused:
Ryland 04-11-2009 10:16 AM
you need to get your free wheel between your drive wheel hub and the spider that the wheel bolts to, so it would look kind of like a wheel spacer, only it would have the free wheel in it, your wheel uses more then one lug to bolt on, correct?
The Atomic Ass 04-11-2009 11:04 AM
Now I think I'm getting the picture, but I still can't picture HOW it would fit there. The rim bolts to the hub with 3 lugs.
I'll have to take some photos when I have it torn down next week or so.
dcb 04-11-2009 11:54 AM
Hmm, I wonder what happens if you have an engine brake with a centrifugal clutch? If you can get the engine to stop and if the clutch will still slip a little then the springs should pull the shoes back. Maybe? Break something? Maybe? ;)
https://www.pmtuning.co.uk/Merchant2...249.011_FP.gif
