EcoModder.com
-   -   mazda3 mpg? (https://ecomodder.com/forum/showthread.php/mazda3-mpg-27517.html)
tjbell 11-12-2013 07:08 PM
mazda3 mpg?
well I've been considering buying a 2004 ish Mazda 3 instead of my Saab 9-5 what are some of you getting for fuel economy
Would be a 5 speed
Flakbadger 11-12-2013 08:07 PM
Would be a 5 speed
If you go to the Garage link, and type in Mazda 3 2004, you can find some results.
EDIT: lots of options for filtering by year, engine size and trim level too!
~Matt
tjbell 11-12-2013 08:11 PM
Underwhelming to say the least. Any other cars that are similar to a 3?
Allch Chcar 11-12-2013 10:30 PM
Avoid the 2.3L and get the 2.0L engine, it's more fuel efficient. There are several options for transmissions and final drive gears.
The Ford Focus shares a lot in common with the Mazda3. Engine, transmission, and even the suspension. The Focus has taller gears and lower profile cam. The Mazda3 has VVT though.
