Old 04-10-2015, 06:51 AM   #1 (permalink)
parabellum's Avatar
Possible aero mods for conventional frame bicycle
I would like to ask if there are any aerodynamic modifications that would do any good for a typical bicycle (in my case this is a diamond frame road bicycle)?
I'm doing 20 km two-way trips every day with little stops.
I've seen some mods like wheel and frame fairings (a flat plate fitted into the front triangle of the diamond frame).
Would a front screen be a good idea?
What about side-wings?
Old 04-10-2015, 09:32 AM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Welcome to the forums!
Give this a read...
Ride Your Bike Faster or With Less Effort Using a Partial Fairing
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 5 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (04-14-2015), Cd (04-10-2015), COcyclist (04-14-2015), parabellum (04-12-2015), Xringer (05-07-2015)
Old 04-10-2015, 09:35 AM   #3 (permalink)
aero enthusiast
Blue beauty - '02 Honda Civic VX
Or aero bars for getting lower?
Or smooth backpack for better wake.... kammback pack!
and definitely high tyre pressure/smooth tyres and lubed drivetrain
i have never tried a curved windscreen
The Following 2 Users Say Thank You to rumdog For This Useful Post:
aerohead (04-14-2015), parabellum (04-12-2015)
Old 04-10-2015, 09:40 AM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
...and more!
Upper Wheel Fairings are designed to give bicycle wind resistance the slip
The Following 6 Users Say Thank You to BamZipPow For This Useful Post:
3-Wheeler (04-15-2015), aerohead (04-14-2015), Cd (04-10-2015), parabellum (04-12-2015), renault_megane_dci (04-18-2015), rumdog (04-11-2015)
Old 04-10-2015, 02:28 PM   #5 (permalink)
Cd
Ultimate Fail
Cd's Avatar
This isn't entirely on topic, but I thought it would be worth posting here for ideas, since this is a conventional bicycle, versus a recumbent :How You Design a Bicycle to Hit 138 MPH on a Ski Slope | WIRED
The Following 4 Users Say Thank You to Cd For This Useful Post:
aerohead (04-14-2015), BamZipPow (04-10-2015), mikeyjd (04-10-2015), parabellum (04-12-2015)
Old 04-10-2015, 08:10 PM   #6 (permalink)
There a number of things you can do to improve the aerodynamics of any bike. The main drag is the rider's body. Decide what position is safe and comfortable for you. Typical road bike position is a 45 degree back angle. A time trial or triathlon bike has the rider's back parallel to the ground. The nose piece and tail box covers from the should down to just below the knee. The width would be about 20 -22" at the shoulder and taper to the knees. Overall length is at least 3 times the width. VERY IMPORTANT! The nose piece needs to attach to the frame and not the handle bars to avoid cross wind input.
See the aero tail box in Alternative Transportation by low&slow. Streamlining a motorcycle is very similar to an upright bike. There is also a thread in the Technical/Bike Building forum at recumbents.com
The Following 3 Users Say Thank You to Grant-53 For This Useful Post:
aerohead (04-14-2015), mikeyjd (04-10-2015), parabellum (04-12-2015)
Old 04-10-2015, 10:18 PM   #7 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by BamZipPow View Post
Nice design. $200 for a $3 worth of coroplast and some brackets seems a bit extreme though.
The Following 2 Users Say Thank You to mikeyjd For This Useful Post:
Fat Charlie (04-17-2015), parabellum (04-12-2015)
Old 04-10-2015, 10:34 PM   #8 (permalink)
Possible design for fairing. Foam or tubing for ribs and sheet material for the skin.
aerohead (04-14-2015), mikeyjd (04-11-2015), parabellum (04-12-2015)
Old 04-12-2015, 07:30 AM   #9 (permalink)
parabellum's Avatar
BamZipPow, thanks for the greeting. I have my account for a few years but I wasn't too active here, though.
It sounds like putting a well-fitted windshield can lower the power output by several watts, now I have to do it myself and check if it works that well for me (I ride almost only in the touring position, I don't do any racings).
These upper wheel fairing are really expensive, maybe doing your own fairing that are integrated with fenders and enclose the whole wheel (with cuts for brakes) would be a cheaper way?
Rumdog, I've seen that some of the pizza delivery men riding on scooters have rucksacks in a prolonged shape, maybe that would be a good base for making a kamback pack
Grant-53, I will surely make the read about the tail box, I'm riding upright so I have to check if it will work well in that configuration.
Old 04-14-2015, 03:45 PM   #10 (permalink)
off-topic
The lower arm and lower leg fairings,integrated into the riding apparel should be emphasized as an opportunity for drag reduction.
Helmet turtledeck and torso boat-tailing can also be applied to the 'back' of the rider jacket.
This is something the Craig Vetter gang is missing on the Motorcycle Forum.
Thank you VERY much for this image! It's worth $billions in savings over the future.
BamZipPow (04-14-2015), Grant-53 (04-14-2015)
