MetroMPG.com mailbag: details of 104 mpg fill-up?
Received this message after someone had a look at the Flea's fuel log:
The fill was in ideal summer conditions, and while it was a mix of sub/urban & rural routes of medium length segments, and a good portion of the driving was on empty or near-empty secondary highways. All were real, "legitimate" trips (ie. didn't displace any bicycle use). To answer your question: none of that driving was in top gear, and very little of it was in 4th gear. The P&G was mostly 2nd to 3rd gear, which is usually between 25-55 km/h. Since installing the taller final drive transmission, the lowest speed I can cruise in top gear on level ground without lugging, is about 65 km/h (~40 mph). Also note that the alternator would have been disconnected for the duration; I would have been running the 12v off a pair (130 lbs) of flooded batteries. |
