Old 12-13-2009, 12:12 AM   #1 (permalink)
Deceptive - '98 Dodge Neon R/T
90 day: 44.38 mpg (US)
Cam Specs (neon)
So i wanted to get some opinions from some of the people here on the differences between the cams available to my car. SOHC is obviously going to be the best for mileage, as the cam grind is not only better, but the valves are smaller. But how about the difference between the DOHC cams. The first is off a neon, the second is from the stratus.
Neon DOHC Cam
Intake Duration: 219.2
Exhaust Duration: 219
Intake Lift: .344
Exhaust Lift: .314
98 Stratus Cam
Intake Duration: 232
Exhaust Duration: 240
Intake Lift: .324
Exhaust Lift: .256
as you can see the stratus cams have more duration, but less lift.
just for fun
SOHC Cam
Intake Duration: 207.2
Exhaust Duration: 229.1
Intake Lift: .283
Exhaust Lift: .277
Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed MetroMPG EcoModding Central 31 11-09-2014 05:28 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Centrifugal cam advance, anyone? beatr911 EcoModding Central 15 10-22-2010 04:15 PM
Shorter duration cam on Chrysler 2.2 engine amcpacer EcoModding Central 3 12-09-2008 09:26 PM
Does anyone know what the EXACT specs are on an XFI cam? RacerX EcoModding Central 2 06-22-2008 11:41 PM
