Minimizing A/C use
I have had a rental car for the last two days. 2010 Chevy Malibu.
At first, I hated the idea of driving this car. Compared to our 2008 Jetta, I just knew that this car was going to be crap. However, I am now eating my words. I am almost completely sold on this car for the simple fact that the A/C system is incredible. As an efficiency guru, I do my best to minimize A/C usage whenever possible. I do this by recirculating the air in the cabin and toggling the cooling function. Unfortunately, the Jetta's A/C is kind of crappy to begin with. Secondly, it seems as though the air maintains its coolness for only a short time before it's warm again (with A/C off and circulate on). This frustrates me to no end. It's almost as if the car is poorly sealed or something. I drove the malibu yesterday for about 30 minutes. With the air circulation on, I turned the A/C on for all of about 2 minutes when I first started driving. THE AIR REMAINED COOL FOR THE REMAINDER OF MY DRIVE. I guess I'd also attribute a bit of this to the fact that the dash board of the malibu is white/beige and the jetta is dark grey/black. I am so pissed at my Jetta. So utterly disappointed, especially considering that the car's gaskets aren't even old, it's a 2008. Please give me some thoughts... On an unrelated note, the malibu was also superior in that it is equipped with instant mpg readout on the instrument cluster. I found that the mpgs of the malibu were quite similar to that of the Jetta as well. |
oh, I forgot to add...
The jetta is dark grey, while the malibu is bright white. I'm sure this makes some kind of difference as well. |
Living as you do in Florida and driving a grey with a black / grey dash car in the N. American Summer with an air conditioner designed for European Summers it is hardly surprising the thing is struggling.
Isn't is obvious? Newer car with lighter colours and designed for the conditions you are driving it in. Peter. |
So is it more fuel efficient to turn on the AC full blast to cool the car then turn it off and then back on when it's hot again or to just leave it one a lower setting to keep the car at a constant cool?
What I do is when I start driving I blast the AC with the Fan on 4, until the temp is where I want it, then I slow the fan down to 2, and adjust the hot/cold dial to where it keeps the temp constant. |
That's interesting.
Also, some fan speed controllers are setup so that they draw the same current regardless of setting. My Jeep draws more current at higher settings than lower. You can test this by checking the battery voltage at different fan speeds while the engine is off. If it always draws the same amount of current, the voltage will be the same regardless of the fan speed. If the current draw varies with fan speed (higher speed, higher current draw) then the battery voltage will be lower at higher fan speeds. If you have the engine on while doing this the readings will be inaccurate due to the alternator charging the battery.
The concept is basically the same as any other method of conservation. By limiting your use of the air conditioner, you are actively conserving fuel. I hope this helps you understand what I'm talking about. I'm certainly more confused now. |
My rule of thumb is to use it as needed to remain comfortable. Hotter temps can cause physiological stress that can effect your driving and your perception as well as your reaction times. I'm much more alert when I'm cool, and get drowsy when it's warmer in the car. I'll take the penalty to remain comfortable and safe.
My original point was that in the Chevrolet Malibu, I was able to remain cool without even using the A/C for 9/10s of the time. Remaining cool while not running the A/C in most cars seems impossible. Desirable, but impossible. The malibu's cooling system combined the best aspects of these worlds. I'm able to cool the cabin to a comfortable level, shut the a/c down and still feel cool for the remainder of my trip. This is what I'm saying: I'M IN AWE. THIS IS A HYPERMILER/ECOMODDER'S WET DREAM, so to speak. |
on my upcoming roadtrip I'll be letting my girlfriend control the AC (YRMV, depending on your significant other) becuase her comfort range in the car is smaller than mine. she complains of it being to cold before I do, as well as complains of the heat before me. Ultimately it will average out fairly well, it won't get as cold, but also won't get as warm before she adjusts it.
Easy and cheap mods would be covering the dash with something insulating and reflective. A couple hundred would buy you good, metalized, heat-rejecting tint. It might be fairly easy to insulate your ducting into the cabin (be careful of the airbags!). More pricey would be to repaint part or all of the car with at least a brighter paint but perhaps even some of that new ($$$) heat rejecting paint (not available in a good black yet). Sheepskin seat covers are serving me pretty well too.
Great call on the dash covers. I've been wanting to get one for both of my cars for some time. My beetle's dash is gigantic and, of course, black.
dieselbeetle -
CarloSW2 |
Joenavy85 -
Thermal comfort - Wikipedia, the free encyclopedia Quote:
i use my a/c no matter what it cost me and don't care i still avg 26-29 mpg in the city with them on and i have heart problems since birth and can't withstand heat...and yeah age of 31 kinda sucks huh i gotta live long in comfortable life!
man I'm learning so much
Impossible. I hate to burst your bubble, but someone has to. A sealed car in Orlando in July will soar to 150 degrees in 30 minutes without AC. It's simple physics. If you don't believe me, just park that Malibu, and sit in it, engine off, for 5 minutes, and see how well your imaginary insulation keeps the car cool.
Your rental Malibu must have automatic climate control. That's even worse than AC, since it's blending cool AC air with heater air to maintain cabin temperature. |
^^^also to balance humidity
@Sentra-SE-R: I am sure you are correct that cars heat up in the sun, but car-off and car running with fan running after running the A/C are really different scenarios. The A/C unit will still be cooling recirculating air for a while. BTW, my tint keeps my car far cooler than you would expect: metalized, heat rejecting, and DARK, I don't get into a cool car, but it's a lot cooler. I'm working on the roof liners after the dash. I'm gonna be cool without A/C one day. |
Oh! Apparently one trim level of the 2010 Malibu (the highest level it seems) does have "climate control" instead of just AC: 2010 Chevrolet Malibu LTZ Sedan 2.4L 4-cyl. 6-speed Automatic Features and Specs
Beaded seat covers help. And I have found that opening the windows a bit 1"-1 1/2" on all four, actually helps the aero at speeds up to say ~50mph. So, I have not replaced the A/C fuse in my xA since last year; and I don't think I have used more than a day or two in the last three years. A little sweat won't kill ya'! Drink cold water or lemonade.
A white roof helps a lot -- this should become an ecomod! |
I hate climate control. :mad: Moon Unit has it and when I select "Vent" sometimes I'll detect the a/c clutch engaging. :mad: So now what I do is select outside temp, get the reading, then match that for my interior temp setting- so when I put it on "Vent" I get "Vent". I'm thinking of installing an a/c clutch cut-out switch anyway, just to be sure.
You're not going to man up to the fact that the Malibu had to have automatic climate control, and you didn't notice it? |
That's gotta be it. So in other words, the A/C IS on even when it's off!!!
If this isn't exactly so, can you help me to understand what climate control means? |
I have 03 Malibu, 95 degrees out today, ac on/recirc on for first 15 miles temp OK. Turn ac off, recirc on, no change in temperature inside car for 15 minutes, turn recirc off, humidity & temp rises in minutes. I think the recirute button overrides the ac switch, it was without adoubt running, no change switching ac button on or off, all highway so I couldn't feel it cycling but I know it was. I'll try with the 10 Impala I bet it works the same.
Here's a great link to some wonderful information about climate control and similar systems and related woes.
Automotive climate control: Information from Answers.com |
...'Mother Nature' has a nasty habit of not stopping the afternoon air temperature at balmy 72ºF but rather always seems to continue UP to 105-110ºF around here (southern California, Arizona, New Mexico, and Texas).
Couldn't agree more. I was in West Texas during the month of June. It got up to 113 during this time. Where A/C is concerned, this was an ecomodder/hypermiler's worst nightmare.
I guess in a car with a larger engine it is more subtle, but in my 1.9l tdi, the draw from the A/C is quite significant. |
Yes, Neil. This should definitely be added to the list. Believe me when I say that ALL of my future vehicles will be white. Unrelated question: what are "trackbacks"...concerning posting to threads? Thanks in advance Neil. |
