EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Mis Fit Talon partial grill block (https://ecomodder.com/forum/showthread.php/mis-fit-talon-partial-grill-block-26837.html)
pgfpro 09-01-2013 09:16 PM
Finished my grill block today using 0.125" polycarbonate sheeting.
I first used 3M weld mask to mock up and a to make a stencil.
http://i147.photobucket.com/albums/r...psdd4a1dbe.jpg
Then laid the stencil on the polycarbonate sheet and traced it out. Then I cut just the straight lines with a cut off wheel and finished the corners with a
80 grit 3M roloc 3" on.
http://i147.photobucket.com/albums/r...psdd4e881c.jpg
Then I applied on the back side of the panels "SEM Bumper Coater" This is SEM's new version that has plastic adhesion promoter built into it.
http://i147.photobucket.com/albums/r...psa015c091.jpg
This is picture removing the front side protective film off the sheeting. What you get is perfect gloss with no imperfections.
http://i147.photobucket.com/albums/r...ps15366211.jpg
This picture is both sides done and ready to install.
http://i147.photobucket.com/albums/r...psb82d9d20.jpg
Another picture of the bumper ready to go on the car.
http://i147.photobucket.com/albums/r...ps9551afe4.jpg
Taken it for a test run in 94* F out on my test loop area.
http://i147.photobucket.com/albums/r...ps8facabae.jpg
http://i147.photobucket.com/albums/r...ps704b9ef0.jpg
Before picture.
http://i147.photobucket.com/albums/r...pse334d50b.jpg
mcrews 09-01-2013 10:03 PM
sweet!
UltArc 09-01-2013 10:20 PM
I think your final production looks awesome, but being so shiny and brilliant kind of distracts from the rest of the car.
pgfpro 09-01-2013 11:48 PM
Your absolutely right. This winter I'm going to paint the car black. It needs a paint job badly.:o
deejaaa 09-03-2013 12:23 PM
any fe gains?
Xist 09-03-2013 02:18 PM
Would you kindly explain your steps in more detail for those of us pirates who do not do anything? :o
pgfpro 09-03-2013 03:51 PM
Originally Posted by deejaaa (Post 388561)
any fe gains?
On my "Instant Mileage" data-log I showed a 1 mpg increase @ 65mph.;)
I still need to do a full tank's worth though.
pgfpro 09-03-2013 05:23 PM
1) The 3m Weld Mask is a one side sticky paper that's used for welding spark. I used it to simulate what it would look like on the bumper. Plus it doubles as a stencil. So you can stick it to the bumper and see what it looks like. Then I used 3/4" masking tape and ran it on the outline of the 3m Weld stencil so later I can match it up to drill the holes.
2) Then I laid the 3m weld mask stencil on on my poly carbonate sheet that measures 14' x 8'. I did a rough first cut with a cut off wheel and kept the corners straight at 90 degrees.
3) Then I used a 3" dia. 80 grit roloc to round the corners.
4) Then I put the poly carbonate grill covers in the 3/4" masking tape outline and pre drilled all the holes and installed them with #10 screws. Then I took them back off and pulled the back side of the protective film off to apply paint.
5) Then I painted three coat's of the SEM brand "Bumper Coater" on the back side. You can find this at your local Automotive Paint Jobber store.
6) Then I let that dry for a hour before removing the front side protective film coating. The film coating serves as a making when painting.
7) Re-installed them back onto the bumper with #10 screws.
After thinking about it you don't even need to take the bumper off.:o
Xist 09-03-2013 08:16 PM
Heh. PGFPro, thanks for the clarification! :)
I decided to try to figure out what I could and when I posted, you had already clarified everything! :)
Is the Weld Mask relatively cheap? Is it like one big flame-resistant sticky note? :)
Did you use polycarbonate because you have fog\sports lights?
Bacon has those, but either they burned out, or I just do not know how to use them! :o I tried to figure out to cover them. I wanted it to look good, but since I did not know if I would notice a difference, I did not want to put much effort into it.
Duct tape looked terrible! It started peeling quickly, too!
Thanks again for explaining everything!
pgfpro 09-03-2013 11:20 PM
Weld mask is not very cheap. lol I had some extra at work so I just used it, but it just like a sticky note with full adhesive not just on the top.
I used the polycarbonate because I had some left over from a race car project i did a few years ago.;)
