EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Miura, a lightweight aerodynamic body over a Volkswagen frame (https://ecomodder.com/forum/showthread.php/miura-lightweight-aerodynamic-body-over-volkswagen-frame-27014.html)
cRiPpLe_rOoStEr 09-21-2013 05:57 AM
https://fbcdn-sphotos-c-a.akamaihd.n...52155917_n.jpg
Look how low it is compared to an Opel Corsa C.
https://fbcdn-sphotos-b-a.akamaihd.n...75190082_n.jpg
And has a nice Kammback.
https://fbcdn-sphotos-h-a.akamaihd.n...45652270_n.jpg
It was made in my hometown from '77 to '85, using the Volkswagen platform, as usual with many artesanal Brazilian fiberglass-bodied cars from the 70s and 80s when imports were extremely restricted.
mcrews 09-21-2013 01:49 PM
Vw beetle?
kach22i 09-21-2013 04:33 PM
Those side scoops seem to be the only source for cooling the air-cooled engine.
Compare to a Type-2 wagon.
OLD PARKED CARS: 1970 Volkswagen 1500 Squareback Wagon.
http://3.bp.blogspot.com/_TsdjySqKQl...agon.++-+2.jpg
I do not think it would have a cooling problem after all (white car, not orange car).
Looks to be fairly aerodynamic outside of vortexes forming at the rear corners.
Gotta love those old VW Beetle based kit cars.
renault_megane_dci 09-21-2013 06:41 PM
Shame the boxer is such a gas guzzler, could do for a nice looking efficient ride ...
kach22i 09-23-2013 12:15 AM
As I understand it the boxer layout is lower in low end torque than lets say a "V", and harmonic vibrations cancel each other out.
I owned a 1976 Super Beetle which got good gas mileage, and currently own a 1977 Porsche 911 which gets 26 mpg hwy - not bad for a 0-60 in seven seconds car (and boxer layout).
Are you sure you are not thinking of a Rotary (Wankel) engine, renault_megane_dci?
renault_megane_dci 09-23-2013 05:03 AM
I red here and there that the VW flat four is no good for FE, is it the Beetl aerodynamic or the engine itself I don't know.
Thing is in standard trim they have a very low CR being air cooled, at the back of the car and dedicated to burn pretty much anything.
This alone does not help FE
euromodder 09-23-2013 06:36 AM
That's because it's an ancient engine design.
Properly designed, boxers can be efficient.
But as most of the boxer designs end up in sporty or sports cars, the engines usually aren't designed for highest FE.
NeilBlanchard 09-23-2013 08:45 AM
The aero of the OP seems to be exactly backward? Turn it around, and it would be much better.
kach22i 09-23-2013 10:32 AM
It does look like it would be fairly aerodynamic backwards too.
Subaru's uses boxer layouts on their engines. I believe the reason they don't get great fuel mileage is because they are AWD.
Air-cooled VW Beetle engine, pre-WWII technology for the most part. Not a modern engine example to be sure.
renault_megane_dci 09-23-2013 03:53 PM
I am not throwing stones to the boxer design for engines, I was saying the vehicle shown can difficultly be made to be some FE champion since it is using the VW flat 4 engine and FE is not one of the strong points of these engines.
