EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   More drag reduction studies (https://ecomodder.com/forum/showthread.php/more-drag-reduction-studies-21204.html)
California98Civic 03-29-2012 08:26 AM
Searching for the author of the paper Vekke posted on drag reduction for the A2, hoping to find more on the rear box fairings, I found a separate paper that expanded the reporting of the "box cavity" findings seen in the paper Vekke posted: "Base Pressure Recovery using Rear Cavity and Base Plates".
And for future reference, in case the longer list of papers paulu found are taken down, here is the "table of contents" for the site:
Session 0-1 - Mike Dickison, Programme Manager Coventry University LCVTP
An Introduction to the Low Carbon Vehicle Technology Programme.
Session 0-2 - Peter White, Professor of ThermofluidDynamics Coventry University, Chairman Automobile Division IMechE
Reducing carbon emissions does aerodynamics matter?
Session 0-3 - Chris Johnson, director, design project work coventry university
Aesthetics and aerodynamics
Session 0-4 - Trevor Haynes, Coventry University
LCVTP Workstream 12: Aerodynamics Technical Introduction
Session 0-5 - Trevor Haynes, Coventry University
Aerodynamics and Electric Vehicles
Session 1-1 - Scott Porteous, Development & Simulation Ricardo UK Ltd
LCVTP Workstream 12 - Aerodynamics Efficiency - Sensitivity Analysis of aerodynamic drag over various drive cycles
Session 1-2 - Gianluca Orso Fiet, MIRA
LCVTP Aerodynamics Process Development
Session 1-3 - Rishi Gupta, Mechanical and Automotive Engineering Dept. Coventry University
LCVTP WS 12 Aerodynamics Support Activities at Coventry University
Session 2-1 - Remus Cîrstea, Coventry University
Effect of rear body taper on a simple body
Session 2-2 - Jeff Howell, Tata Motors European Technical Centre
WS12 Aerodynamic Performance University Research Projects Base Pressure Recovery
Session 2-3 - Nick Sabrazat, MIRA
LCVTP Aerodynamics Reference car finding:Lessons learned
Session 2-4 - Adrian Gaylard, Technical Specialist Aerodynamics Jaguar Land Rover
Session 3-1 - Jeff Howell, Tata Motors European Technical Centre
WS12 Aerodynamic Performance University Research Projects Wheel/Wheelarch Drag
Session 3-2 - Adrian Gaylard, Technical Specialist, Aerodynamics, Jaguar Land Rover Drag Reduction Through Wheel Design
Session 3-3 - Nick Sabrazat, MIRA
Wheel Arch Flow Investigation
Session 4-1 - Hussain Ali, Tata Motors European Technical Centre
Drag reduction on a production vehicle
Session 4-2 - David Plummer, Design Institute Coventry University
Aesthetic Design
Session 4-3 - Adrian Gaylard, Technical Specialist, Aerodynamics, Jaguar Land Rover
Further Opportunities
Posters
Posters 1
Posters 2
drmiller100 03-29-2012 11:33 AM
http://wwwm.coventry.ac.uk/researchn...ple%20body.pdf
This article is IMPORTANT. I recommend you save it, read it, and learn it.
This article is saying you can reduce drag 40 percent by making a tail. And the tail does not have to be very long.
And according to them, 20 degrees is about the absolute max, and even at that you are going to have problems with the bottom, but it is still worth it.
This article is worth SAVING.
California98Civic 03-29-2012 09:55 PM
Very interesting. Some of it looks like a section on tail end shapes in Hucho, but this has more images and discussion than what I recall. There are a few articles in that table of contents that should be of interest here.
Otto 03-29-2012 11:31 PM
Did I read correctly in thinking that 80 degree taper = 80 degree angle from the vertical tail section, or 10 degree diversion from horizontal?
jtbo 03-30-2012 05:16 AM
I guess so, 90 degree would be level, so 80 degree would be 10 degree off from level position, that is how it seems to be when comparing pictures on that document as 70 degrees is much more steeper angle, meaning it is 20 degrees off from horizontal.
edit:
For 1.33m height, one after body would be 0.1064m long so two would be 0.2128m long, which would then need to be angled to 10 degrees angle downwards from trailing edge. That sounds horribly lot what I had in my car last summer and would explain my fuel economy gains a bit, even I did not have full height sides or bottom in there, also it means that there is lot more to be gained.
drmiller100 03-30-2012 10:26 AM
I read it as 80 degrees is 10, and 70 degrees is 20.
I also read it as 20 is probably fine for the top of the roof, and 20 works for the sides, but does not work for the bottom of the car unless ground clearance is "right".
jime57 03-30-2012 05:44 PM
The base cavity and base plates kinda blew my mind. I don't think Hucho addressed either so that was a great surprise. It is also interesting that they claim large gains from such short cavity lengths.
I was also totally brown away by the base plates. I would have thought that there would have so much turbulance between the body and base plate that it would have been counterproductive. Definitely some new ideas here.
What you thinking Phil?
aerohead 03-31-2012 03:38 PM
Hucho
Hucho addresses this technology back in the commercial vehicle chapters.These plates are exactly what Continuum Dynamics developed at NASA Ames Research Center,Palo Alto,California decades ago.
I did one of these 'egg crate' boat tails behind my semi model and it flowed just fine.
By limiting where the air can be,and providing locked-vortices all around,the outer flow can skip over the egg crate as with Texas Tech's cab wing/half tonneau on the pickup.
They're not as good in a crosswind,but they're way out ahead of nothing,extremely light,easy to manufacture,and should cost very little.
euromodder 03-31-2012 05:54 PM
The pick-up rear gate / partial bed cover seems a good analogue when trying to understand how these base plates work.
And when disguised as a cargorack or bikerack, or actually doing double duty as a rack, it won't draw that much attention.
Cd 03-31-2012 06:32 PM
( Actually, to be fair it should be mentioned that Paulu made note of the studies posted here on page 2 of the original thread - but its good to have a dedicated thread on this. )
Cd 03-31-2012 06:35 PM
Hey Euro, I like your thinking !
Clever idea using a bike rack disguise !
California98Civic 03-31-2012 06:44 PM
Me too.
I did note it, and linked to his post, in the OP of this thread. I was unaware of his post at first. When I saw it, I edited this post and also asked the moderators to consider merging the threads, but Metro thought there was enough difference to keep them separate. My OP was mostly interested in expanded detail on the specific drag reductions attained through the box cavity designs. That was not part of what paulu noted.
Sven7 04-24-2012 11:55 AM
I've been thinking about this some more. Do you think a sedan owner could create a plexiglass baseplate sticking up vertically from the trunk edge, essentially creating a phantom Kammback? This would be less intrusive than making the trunk unusable but would it give meaningful drag reduction?
PaleMelanesian 03-19-2013 10:59 AM
Research
Link is broken. Anyone have a copy?
christofoo 03-19-2013 12:12 PM
Looks like Coventry broke all the links, and I'm not sure how to find any papers anywhere on their site - which is sad, I haven't read them.
It looks like I had some luck searching the web for a few titles though:
http://www2.warwick.ac.uk/fac/sci/wm...baseplates.pdf
http://www2.warwick.ac.uk/fac/sci/wm...simplebody.pdf
kach22i 03-19-2013 07:36 PM
Here is one specific to drag on electric vehicles, also covers wheel openings (and more):
http://www2.warwick.ac.uk/fac/sci/wm...tationws12.pdf
California98Civic 03-19-2013 09:45 PM
On page 10 their scale model testing shows a tiny benefit for "blanking" the wiper cavity. And their biggest benefit was with the rear diffuser.
christofoo 04-04-2013 01:12 PM
Another point I notice in this doc is they used OpenFOAM for CFD - never heard of it, but found it here: The OpenFOAM&#174 Foundation. (I also could have found it just googling 'open source CFD,' though it's nice to know what Universities have chosen for CFD.) OpenFOAM is open source / free, looks easy (for me) to install or build for Linux *not for Windows*... but the learning curve appears very steep. Momentarily I couldn't find an answer to how you import solid objects into the OpenFOAM mesh generator, i.e. from a NURBS or Polygon file format, which is key. But I think I remember some separate open-source projects that stand alone as mesh generators, so I think there is a solution outside the scope of OpenFOAM. (Finally in order to delve into CFD one would have to consider how to setup some correlation between CFD and wind-tunnel data (preferably someone else's published wind-tunnel data), to ensure the computation is configured sensibly. Overall I'm not sure if it's worth the investment of (my) time, but it's always a temptation in the back of my mind... and now I know the name of a viable CFD suite...)
euromodder 04-04-2013 01:34 PM
You'll find them here, amongst other stuff:
https://www.dropbox.com/sh/52o49bkru...modder_studies
PaleMelanesian 04-05-2013 10:50 AM
Outstanding! Too bad I can only give you one Thanks for that post.
http://ecomodder.com/forum/images/bu...ost_thanks.gif
California98Civic 04-05-2013 11:36 AM
Originally Posted by PaleMelanesian (Post 365141)
What he said.
aerohead 04-06-2013 02:29 PM
baseplate
Could you do a 'back of the napkin' sketch,I'm having difficulty visualizing this.Sorry!:confused:
California98Civic 04-06-2013 02:52 PM
I honestly don't think so:
http://www-mdp.eng.cam.ac.uk/web/lib...t%20bodies.gif
Though perhaps a little depends on how high your vertical plexiglass plate rises from the trailing edge of the trunk lid?
james
aerohead 04-06-2013 03:01 PM
Cds
james
I don't know the source of the pictorial drag table and associated Cds,but the numbers aren't in agreement with anything I've ever seen.:confused:
California98Civic 04-06-2013 04:34 PM
Oh, darn. Nevermind. That's what I get for avoiding looking things up and just trying to get relevant info quickly. Sorry. But it is true that a vertical plate will have high drag, no?
aerohead 04-06-2013 04:55 PM
flat plate
Yes,next to a parachute they have about the highest drag.
Hoerner,Fachsenfeld,and Hucho(who uses Hoerner) show around Cd 1.11 for a flat plate.
'Conventional' parachutes are Cd 1.35
A 1906 Buick Model C Touring Car was measured at Cd 1.03 according to Tremulis.The highest drag ever measured for an automobile.
CAR and DRIVER's Don Sherman who did the Crisis Fighter Pinto and Z-Car found that when rear spoilers went above a 30-degree angle(from the horizon)that drag began to grow higher.
The Guerney Flap is vertical,but does not project vertically very far.Maybe an inch for the Ford Torino Talledega of 1969.
riddleyo 04-10-2013 11:56 AM
3 Attachment(s)
I think he is talking about these. I've seen them used in autocross to impart downforce on the rear tires, but if they are properly sized, it may create the "Phantom Kammback" effect we are seeking.
aerohead 04-13-2013 01:41 PM
these
Thanks for the images.
Since the context of the photos is 'auto-crossing',then I'm presuming that the racers are trading speed for downforce (since highest attained speed in autocross is relatively low in comparison to other track racing).
Every example shown would incur a MPG penalty.Careful 'tuning' of size and angle could achieve a drag minimum at zero-yaw,but in a crosswind the benefits would be dubious.
For $2,000/hour,at Lockheed-Marietta you could find out.Eventually.
Vekke 07-25-2016 04:25 PM
I got a tip of this saab study today:
http://publications.lib.chalmers.se/...ext/143210.pdf
paconassa 08-22-2016 09:54 AM
dropbox com/sh/52o49bkrua0tb5m/0qtRLnijtK/ecomodder_studies
Could you share this again?
Does someone have this files?
Thanks!
freebeard 08-22-2016 04:55 PM
euromodder's latest post was in March, about the time of your first post, Mr Join Date 2009.
What are you looking for specifically? I wouldn't feel comfortable re-upping anything I have. A lot of it has been paywalled. Your best bet might be searching Ecomodder threads to see what others found of interest.
The interesting work was done at Coventry University and presented as Powerpoint slides, and by Robert Englar at Georgia State. So a search on Ecomodder on 'coventry' or 'englar' — or on the deep, dark web — might be of interest.
paconassa 08-22-2016 05:01 PM
I'm interested in the LCVTP slides and pdfs from the first post, can you help?
Thanks
freebeard 08-23-2016 01:39 AM
Well, I'm on a totally different system nowadays, but there's this in my albums:
http://ecomodder.com/forum/member-fr...31-1-26-08.png
The thread's about how the trail went cold, so what I did was to go to the first post and find the name Adrian Gaylard. I remember him from then, so I took that to Google. Last link on the first page of results is to some of his newer work. In the right sidebar is this:
The Effect of Base Bleed and Rear Cavities on the Drag of an SUV
Voila! Try page three. The docs I currently have saved out are available at:
http://www.vortaflow.com/consulting/...0reduction.pdf
https://www.google.com/url?sa=t&rct=...29759880,d.cGc
HTH
paconassa 08-23-2016 03:19 AM
thanks for sharing that.
Unfornatly for me, I'm specially interested in the wheel and wheel archs flow studys... :(
What I have so far:
https://www2.warwick.ac.uk/fac/sci/w...tion120221.pdf
https://www.ara.bme.hu/oktatas/tanta...larch-drag.pdf
freebeard 08-23-2016 11:47 AM
In that first link, task 12.3 has a later version of the screenshot I posted and is a better paper overall.
I found another folder of stuff. Try: https://www.ara.bme.hu/oktatas/tanta...larch-drag.pdf
paconassa 08-23-2016 12:10 PM
Your link is the same as the second I posted.
I've tried to contact nick sabrazat via LinkedIn, no luck so far.
freebeard 08-23-2016 03:56 PM
Perhaps this doesn't have my full attention. :o
PDF file names , session numbers and actual titles. ?????? Sorry I'm not more help. It's August.
Perhaps session 2-3? I can't find it via Google
LCVTP Aerodynamics
Reference car finding: Lessons learned
Nick Sabrazat
MIRA
19th October 2011
Contents
1. Introduction
2. Back-end optimisation
3. Vortex generator investigation
4. Base plate offset investigation
5. Conclusions
paconassa 08-23-2016 06:15 PM
No worries mate :)
As soon I have the files from Nick, I'll put them here.:thumbup:
Vekke 08-20-2020 04:03 AM
Found a new interesting study, Wheels+covers, spats, fender skirts and stuff. Take a look:
http://publications.lib.chalmers.se/...512/250512.pdf
freebeard 08-20-2020 11:22 PM
Thanks.
I've only gotten to 4.2. It's interesting how front wheel spats can affect the wake.
