More EPA slight of hand.
Guide on State Summer RVP Standards | Fuels and Fuel Additives | US EPA Wonder what the effect on FE will be. |
Evaporative emissions are less of a problem nowadays. Fuel systems in modern vehicles are sealed, and the computer warns the driver when a leak is detected. Further, many counties require DEQ checks which include the requirement that the vehicle not have any leaks in the fuel system.
Gas cans are even required to be sealed. I remember as a kid having metal cas cans with an unsealed metal spout. All gas cans sold now are sealed up, and I don't have a single old can anymore that is open to the air. I'm also curious what the allowance of the regular fuel will do for fuel economy. |
Originally, gasoline here in Phoenix and Tucson (EPA-declared "smog" areas!) had to use E10 gasoline year-around...but, now, it's been relaxed to "...up to 10% ethanol..." year-around, so the actual amount of ethanol varies.
If the cleaner gasoline was doing its job and it's only 7 cents a gallon more at wholesale why not use it everywhere?
...because not everywhere has BAD air...and most of those places that do, it's more often due to geophysical (basin) characteristics and weather (inversions), and NOT always cars and hydrocarbon emissions!
For example, EPA keeps beating AZ up about it's DUST storms as if the residents are responsible for (a) blowing winds, (b) desert sands, and (c) weather conditions causing those winds! Duh! |
Sounds like they will be able to leave more butane in gasoline. |
Don't see how 7 cents a gallon wholesale is going to make a big difference in price. |
I have a problem. |
