motorcycle conversion. What size motor?
I'm building an electric motorcycle from an old Honda 250cc, and I have the choice of a 5kW or a 10kW motor at $700 ish and $1050 ish $AUD respectivly. Just wondering if the 10kW is total overkill.
I don't want a feeble bike that will struggle up every hill, but I dont need a raging death machine either ... :) Interested in opinions. Andrew. |
you might need to narrow it down a little more, 10kw is in no danger of being a raging death machine FWIW :) That kw takes a single speed 332lb (plus rider) brammo through the 1/4 mile in 20 seconds with a top speed of 65mph-ish
Thanks
The 10kW is 17Kg, the 5kW is 11Kg, so the weight isnt significant (compared to the batteries + bike). For the extra few hundred $$ it seems like it will be worth it. Both motors come with water cooling options, which since the bike has already has a radiator, seems like the thing to do. |
Go with the 10KW motor.
Your not going to have a transmission so the more powerful motor will be needed to have descent performance. |
*smirks*
I thought politics were banned here?? |
