Originally Posted by P-hack
you might need to narrow it down a little more, 10kw is in no danger of being a raging death machine FWIW  That kw takes a single speed 332lb (plus rider) brammo through the 1/4 mile in 20 seconds with a top speed of 65mph-ish
Thanks, That's pretty much what I needed to know I guess.
The 10kW is 17Kg, the 5kW is 11Kg, so the weight isnt significant (compared to the batteries + bike). For the extra few hundred $$ it seems like it will be worth it.
Both motors come with water cooling options, which since the bike has already has a radiator, seems like the thing to do.
