EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Motorcycle fuel gauge (https://ecomodder.com/forum/showthread.php/motorcycle-fuel-gauge-2131.html)
dcb 05-02-2008 11:58 PM
If you ever owned a bike, you probably thought about doing this at one point :)
Yes, poking a hole in a gas tank is a nerve racking task, do it at your own risk. But it is pretty easy after that, the other end connects to a TEE inserted in the fuel line.
http://opengauge.org/cycle/fuelgauge.JPG
LostCause 05-03-2008 12:08 AM
Are you making an old school sight tube, or is this for the laser apparatus you've developed?
- LostCause
dcb 05-03-2008 02:42 AM
Right now it is just an old school sight tube, but having a vent tube can be handy for other gizmos. I really like having it though, it is way better than nothing, I should try and put some marks on it.
bennelson 05-03-2008 09:18 AM
I like it!
It fits the criteria of cheap and functional!
Also, anything you can homen-brew instead of running out and buying a "product" gets points in my book.
If I punched a hole in my tank, all the electrons would fall out....
