MPG calculation with non-stock tire size?
I'm not sure how to calculate miles driven with a non-stock tire size. I can't remember if you multiply the miles driven to the % difference in speedometer reading, or what.
Thanks in advance! |
Yes, you need to calibrate the odometer (by driving a marked distance on the highway, or measuring it with GPS, or measuring it in GoogleMaps) and then adjust the odometer reading by a percentage to correct it.
Alright. The new tires I'm getting will cause the speedo to be 2.3% slower, according to this: Wheel-Tire - WWW.RIMSNTIRES.COM size comparer&sw1=185&ar1=70&bd1=14&rw1=6.5&et1=45&sw2= 195&ar2=70&bd2=14&rw2=6.5&et2=45&text1=&text2=
Can I use that percent, or will the odometer reading be changed by a different percent so I have to go a set distance and compare? |
AeroModder -
I use tire calculators and then I cross-reference my odometer trip meter against a GPS : http://ecomodder.com/forum/showthrea...ires-2642.html CarloSW2 |
Thanks for the info, but I don't have a GPS to go by, and can't afford one, especially after ordering the new tires. ^^;
But from reading that, it looks like the percentages for the speedo and odometer are the same. So, if I'm not mistaken, the formula would be: Distance reading x % correction = Distance error Distance error + Distance reading = True distance And in my case it would be about: 250x0.02=5 5+250=255 Is that right? |
AeroModder -
Yup, that's what I do. My tires account for a +2% "bonus" when I fill-up. To keep track of what is going on, this is my typical "Details" section of my Fuel Log : Quote:
CarloSW2 |
Sweet. Thanks for the help! ^^
