Old 05-29-2008, 04:18 PM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
My Continental Contact-Pro Tires
Hello -
I just got these Continental Contact-Pro tires around June 3rd, 2007 :
New tire size : 195/65 R15
Stock tire size : 185/65 R15
Here are some specs on the tire :
ContiProContact
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Code:
Size                  = 195/65HR15
UTQG                  = 400 AA A
Max Speed             = 130 MPH
Max Load              = 1356 lbs.
Max. Inflation Press. = 51 psi
Tread Depth           = 10/32"
Tire Weight           = 18 lbs.
Rim Width Range       = 5.5-7"
Meas. Rim Width       = 6"
Sect. Width           = 7.9"
Tread Width           = Not Available
Overall Diam.         = 25"
Revs Per Mile         = 835
These tires are one size up from stock. Rated up to 51 PSI, currently running at 51 PSI after ~7 miles of city driving.
I used this site to figure out my difference in speedometer readings :
Miata.net Tire Size Calculator
http://www.miata.net/garage/tirecalc.html
It told me that the speed will read 2.1% too slow.
I don't use my ScanGauge for my mile/distance readings, I use my car odometer with a GPS correction. Here are the two GPS correction tests I have done using my wife's eTrex GPS :
Code:
              Car Odometer    GPS       GPS/ODO    % Correction
2007/06/19    19.00           19.6      1.0310     +3.1%
2007/06/19    36.15           37.2      1.0290     +2.9%
Almost 6 months later :
2007/12/01    30.40           31.2      1.0263     +2.6%
2007/12/05    31.40           32.3      1.0286     +2.9%
I am sticking with a 2% error correction on my gaslog because I don't want to accidently inflate (ha ha) my MPG numbers. Also, tire wear will eventually bring this correction down over time (i.e. always losing tread => always reducing tire circumference => always reducing odometer error over time).
The only problem is that on freeways that are grooved in the direction I am traveling, the car "wiggles", aka the tread tracks into the grooves like a phonograph needle and the car has a noticeable wiggle. I had a feeling this might happen, but no proof until after I bought the tires. Thank goodness my main commute only has this for maybe a mile or two. My wife's new GoodYear Eagle GT's do the same thing to a lesser extent.
Back in the day it was MUCH worse on my motorcycle,
CarloSW2
American Solar Energy Society
Old 05-29-2008, 04:36 PM   #2 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Do you know the Rolling Resistance on the new treads?
I used to have the Eagle GT's on a '90 Beretta. Brand new, they hyroplaned like crazy (stuck to the road pretty well, though). With the higher pressures on my Michelins, the biggest difference is cross-wind stability. It takes a bit more steering feedback to keep it straight.
Yeah, Kansas City has a higher wind speed average than Chicago (the "Windy City").
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 05-29-2008, 04:58 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
RH77 -
RH77
I started from this document :
LOW ROLLING RESISTANCE TIRES - March 2003 - Page 5
http://www.greenseal.org/resources/r...resistance.pdf
Code:
BRAND                        = Continental ContiTouring Contact
MODEL                        = CH95
SIZE                         = 205/55R16
RRC AVERAGE                  = 0.0083
PRICE                        = $64.00
TRACTION COMPOSITE           = 7.46
WOULD BUY AGAIN              = 6.10
COMPOSITE TREAD WEAR         = 7.29
COMPOSITE PERFORMANDCE SCORE = 6.95
Here's a picture of the Continental ContiTouring Contact from tirerack :
My tires are not an exact match, but they have the same "pedigree" (fingers crossed ). I didn't get the tires from the GreenSeal document because I could not get the size I wanted that was also rated at 51 PSI, .
CarloSW2
Old 05-29-2008, 05:28 PM   #4 (permalink)
RH77's Avatar
That's a good value vs. RR. I think you'll find the treads a fine addtion to the Sat. Plus, the 51 psi certified max PSI is an added assurance.
As for the circumference, an adjustment to the SG may be necessary -- not a big deal. I usually have mine set to the most pessimistic settings so I try harder. The displayed FE prompts additional effort if it's perceived as low. The trick is to disregard the setting and shoot for that higher goal. Hopefully, I'll have 2 record tanks through this and lower cruise speed.
Let us know how the new tires work out!
RH77
EF5 / 22-May-2011
_
_
Old 05-29-2008, 05:40 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
RH77 -
RH77
Thanks for reminding me. I have adjusted the SG to show a +2% speed increase on the MPH, so it is accurate for these tires.
I will be doing a GPS adjustment in the next few weeks, so I will add the results to the thread.
CarloSW2
Old 10-09-2008, 05:37 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
I just did another GPS correction test :
Code:
2007/06/19    19.00           19.6      1.0310     +3.1% (after purchased)
2007/12/01    30.40           31.2      1.0263     +2.6% (6 months later)
2008/10/08    34.1            35.1      1.0293     +2.9% (16 months later)
2008/10/09    35.6            36.5      1.0253     +2.5%
In the 2008/10/08 test, I wasn't being smart and did some strategic EOC, so I am sure that it contributed to the higher % (when you turn the key to the off position, the car odometer stops, but the GPS keeps right on chugging).
In the 2008/10/09 test, I was much more careful. I *like* that the % is going down over time. This is consistent with tread wear.
As stated before, I am sticking with a 2% error correction on my gaslog because I don't want to accidentally inflate (ha ha) my MPG numbers. Also, tire wear will eventually bring this correction down over time (i.e. always losing tread => always reducing tire circumference => always reducing odometer error over time).
Me happy, .
CarloSW2
Old 10-09-2008, 09:45 PM   #7 (permalink)
RH77's Avatar
Kudos on your accuracy! I really need to do this
So the Odometer quits when the key is out? Weird -- I didn't know that some cars did this. It makes sense if the intention is to tow the car behind a motorhome as many Saturns are designed to do.
RH77
EF5 / 22-May-2011
_
_
Old 06-02-2009, 03:04 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
Code:
2009/06/01    29.2            30.0      1.0273     +2.7% (24 months later)
2009/06/01    44.0            45.2      1.0272     +2.7%
It's still pretty much dead-on. My intuition was predicting it to decrease, but maybe that will happen in due course.
I just got the tires rotated and they didn't say there were any wear problems. When I get the rotation I drop the PSI to 42 to avoid lectures, and fill 'em back up to 50 PSI afterwards.
Me still happy, .
CarloSW2
Old 08-01-2009, 08:29 PM   #9 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...The only problem is that on freeways that are grooved in the direction I am traveling, the car "wiggles", aka the tread tracks into the grooves like a phonograph needle and the car has a noticeable wiggle.
...My wife's new GoodYear Eagle GT's do the same thing to a lesser extent.
...samething occurs with the OEM Goodyear Eagle RS-A's on our '09 Vibe.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 08-02-2009, 02:54 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Old Tele man -
Yeah, at first glance the RS-A's look similar to mine and a Prius OEM :
Your Eagle RS-A's :
My ContiProContacts :
Toyota Prius Goodyear Integrities :
And, I think my friends' Prius also has road wiggle. Your OEM tire is usually picked for upping MPG to increase the EPA MPG score. Maybe that's a clue that we have a tread pattern that is conducive to LRR.
Hrmmmmm, this makes me wonder. If it fits, should I try Prius OEM tires next time?
CarloSW2
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 07:12 AM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 62 03-12-2011 03:58 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
New tires, advise? Chris D. EcoModding Central 35 06-09-2008 10:53 AM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 03:49 PM
