EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Mpg drop in winter. (https://ecomodder.com/forum/showthread.php/mpg-drop-winter-37043.html)
royanddoreen 11-27-2018 03:20 PM
Mpg drop in winter.
I guess I would be right in saying that a hybrid loses more mpg due to cold weather than a car with ice only. Living in this cold climate I’m probably not getting as big a gain from my last car ice as I hoped I would. Never factored this variable in when I bought my Niro which was getting 4.5l/100k now i’m Getting 6l/100k which is still decent I know.
oil pan 4 11-27-2018 04:40 PM
I drive an all electric leaf and I am seeing around a 20% drop in range and economy.
Daox 11-27-2018 04:49 PM
I think the mpg drop is very similar in hybrids and gasoline only vehicles. Hybrid's gas mileage is just so much higher that the numerical value drop makes it seem like its larger.
cowmeat 11-30-2018 12:23 PM
I saw about a 20% decrease this morning when I turned on the heater in the Volt
twj347 11-30-2018 02:50 PM
Not sure how cold it is where you are, but that's pretty typical. There are a lot of factors that reduce economy in cold weather:
- cold engine
- cold transmission and differentials
- higher air density increasing aero drag
- higher air density increasing engine pumping losses.
- spinning on slick surfaces, or slow traffic on slick surfaces
A block heater helps quite a lot for shorter trips. Grill blocks will help a bit too.
S Keith 11-30-2018 05:48 PM
Cold weather, ICE vs. HEV
HEV may take a bigger percentage hit due to:
1) the inherent loss of efficiency the ICE experiences in cold weather
2) HVAC heating demand forces ICE to run when it otherwise wouldn't
3) when hybrid batteries are cold (NiMH < 50°F), the battery utilization is seriously throttled thus reducing the hybrid efficiency, primarily in regenerative braking.
oil pan 4 11-30-2018 06:46 PM
I don't have NiMH or internal combustion engine in my car and see a pretty dramatic drop in range and economy.
S Keith 11-30-2018 06:48 PM
Which is completely irrelevant because the OP is asking about HYBRIDS.
Thanks for chiming in though.
oil pan 4 11-30-2018 06:54 PM
I'm just saying the economy loss we see isn't all due to the internal combustion engine or battery being cold.
For me it takes more power to maintain speed when cold.
So cold tires, cold transaxle oil and increased air density would be shared between gas, hybrid and pure electric.
Bill the Engineer 11-30-2018 08:30 PM
Hybrids lose mileage in cold weather because the IC engine has to run more often to keep the emission control components warm enough to work properly. There are LOTS of postings over at priuschat.com about this.
Bill the Engineer
