MPG losses from car stereo ?
I searched previous threads, but did a quick, sloppy job, so I may have missed it ........ so, here is the question :
If I replace my car stereo with a NORMAL stereo and speakers ( no huge mega subwoofers ) What kind of mileage drop should I expect while using the stereo ? O.K. Just for comparison, WHAT IF I did go all out and install a fancy subwoofer and all ? What kind of mileage drop should I expect then ? |
Normal stereos don't pull much juice thankfully. I can't speak for a mega setup.
Even in a mega stereo configuration, your mpg loses will likely be drawn from the weight of the equipment. That then would depend on the weight of the components, like box, amps, speakers, sound deadening.
A "normal" stereo, as in an aftermarket head unit pushing aftermarket speakers in factory locations will draw between 2 and 6 amps of current at normal listening volumes, peaking as high as 12 or so amps under the heaviest of loads, momentarily.
This isn't much at all, nor is the weight significant - I would consider its impact on fuel consumption trivial at best. Throw a modest subwoofer and modest amplifier in the mix (not the kind of thing you hear 6 blocks away... just adequate augmentation to a normal stereo) and you're still under 10 amps typical current consumption at less than full volume listening. The guys who are really serious about car audio might have systems drawing over 250 amps of current and subwoofer enclosures weighing over 400 lbs.... but that's probably not what you were asking about ;) |
if youre crazy like me, you can rip out all your speakers but the one by the driver door. minimize that power draw
I have only one speaker too. All mine were blown, so I removed all but the least blown ones.
It really sucks when listening to songs recorded in stereo. :) Still looking for someone who's replaced their factory 6.5 inch round speakers to replace my fronts. |
I find the losses from the radio are not from the power draw, but from the distraction. I can't focus as well and so I don't hypermile as well.
If both of the stereos are outputting the same volume, the difference is probably nil -- not worth worrying about.
If you're concerned about weight, have you looked at your own bodily weight? Reducing that will bring benefits to any vehicle you ride in, and consuming less will mean fewer trips to the grocery and overall less impact to the environment. |
1 HP = 746 watts. I see typical stereos advertising 200 watts/channel, so if you crank the volume to the max (goodbye, eardrums!) you could theoretically lose about half a horsepower.
Of course in the real world, you'll be using less than that even at full volume, because the sound level will vary... |
Hi James,
There is probably very little connection between what an amplifier is rated at, and what it actually is able put out into a dynamic load (the loudspeaker and it's crossover). Also, there will be losses since no amp Class A/B amp can be very efficient, by definition. |
What this means is, for all practical purposes 100% of all in-dash car head units you can buy are working with 0-12 (or 14.4 under ideal conditions) volts and the vast majority use BTL configured output transitors with a 0.5/1 bias. 14.4 volts into 4 ohms is 51.84 watts *peak* theoretical power per channel, if there are no losses anywhere else in the circuit. Which means RMS sine wave average output will be roughly half that, again under ideal circumstances. So you have 21 watts times 4 output when all 4 channels are rockin' full boogie 100% of the time, or 84 watts. Figure the head unit's other items (illuminated display, DSP, mechanical cd transport, etc) will use another 20 watts or so, and the whole shebang isn't going to be 100% efficient since BTL A/B type amplifiers - even chip amps like are typical in this application - are at best 75% efficient. So you're around 140 watts absolute maximum continuous draw under the most extreme theoretical conditions at full volume. I really doubt anyone drives around playing sine waves at 100% volume all the time... so figure the radio at a reasonably loud volume is going to use less than 40 watts average. Not a concern worth even thinking about. Sadly, no law prohibits manufacturers from making up ridiculous wattage claims for their products except specifically home hi-fi equipment. That is why $15 PC speakers can claim to be 1000 watts, and car stereos can claim to output ridiculous amounts of power. They arrive at those numbers using whatever funny math they want to justify it with, (for example, you can see above in my math how Sony arrives at "52w x 4" from their head units... 14.4x14.4 divided by 4 ohms equals 51.84 watts... rounded up is 52) |
Good to know.
I had the impression that these things were power hogs. I have seen lots of stereo setups where the guys had to have seperate batteries in the trunk just for the stereo. |
Basically any time you want to increase output by 3dB you have to double wattage. A normal speaker might produce 90dB at 1 watt, to make it produce 93 dB you need 2 watts, 96dB you need 4 watts, 99dB you need 8 watts, 102dB is 16 watts, and before you see 105dB most regular automotive head units are unable to produce any more wattage. (ignoring "cabin gain" here) But you can see how this turns into serious electrical demands when guys are trying to get 140, 150, etc dB out of their system. The same 90dB efficient loudspeaker would need more than 8000 watts to produce 129dB (assuming it could handle the power) |
Just depends on how crazy you go.
If you go big, then think about efficient amps+ speakers. The *Last* time I drove a VW it had a monster stereo, you could definitely tell the difference in performance when it was cranked I'd guess that had something to do with the terrible economy. Obviously you have to look at average current draw (never displayed) to determine how bad you will hurt economy. |
GM considers stereo draw significant enough to have given BOSE the task of improving unit efficiency for use in the Volt:
Why couldn't they use TI's hybrid digital technology to improve efficiency? I have done it for home audio:
Amanda Harris: the Prius of home audio - EcoRenovator Quote:
I remember a friend of mine in high school who turned up the (aftermarket) stereo so loud that the lights were dimming... and then complained that gas is too expensive! |
In any case... there's still really nothing to chase with a regular car stereo. Before anything else I'd suggest the added weight of a big subwoofer is the most significant enemy of fuel efficiency in a car stereo because it is rare for anyone with a serious system to just drive around everywhere with it turned up. When they're not turned up loud, they don't draw much current because of the previously mentioned relationship between deciBels and wattage. If you have a "regular" stereo and are a casual efficiency hobbyist, stop worrying about the stereo right now, it's not the droid you're looking for. If you are extreme about efficiency, rip the whole thing out and wear an ipod because the weight of the parts is affecting your efficiency even when it's turned off. |
Here's some information on the stock stereo system in the Prius:
Prius JBL Audio system response, specs, and photos Halfway down the page, there's a few (not very good) pictures of the amplifier module. From what I could tell, there's two Analog Devices chips (DSPs? Hybrid audio amp controllers?) and an inductor that appears to be part of a DC/DC converter circuit. |
