EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Mpguino built, registering VSS when the wire is not hooked to anything (https://ecomodder.com/forum/showthread.php/mpguino-built-registering-vss-when-wire-not-hooked-20903.html)
dwills898 03-08-2012 11:59 PM
I just built my mpguino and it looks like it is working but it is registering VSS and I think the Injector signal when their respective wires arent hooked to anything. Anybody have any suggestions, I have no experience with this stuff. Thanks
dwills898 03-09-2012 02:10 AM
I just cut the 2 sensor wires shorter and now its not doing it anymore. Was it just radio interference or something?
Ecky 03-09-2012 07:03 PM
Maybe, the MPGuino is highly sensitive. Touching the ends of the wires on mine causes it to read something.
Make sure your resistor is very close to the MPGuino-end of your wire.
EDIT: In answer to your question in the other thread, I have the diodes and resistors soldered to wires within an inch of the board.
Congrats on the successful build!
