EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   MPGuino Buttons (https://ecomodder.com/forum/showthread.php/mpguino-buttons-24571.html)
gijoe985 01-09-2013 09:05 AM
MPGuino Buttons
I recently received a fully assembled MPGuino. There are three buttons coming out the top, soldered to the 1,2,&3 ports on the board. There is also a EXT Buttons section on the board with holes for buttons 1,2,&3 as well as a common ground.
My question, if I wanted to have remotely mounted buttons, would it be better to desolder and resolder the current buttons, or use the EXT Button holes? I think I am going to mount it inside my instrument cluster, so I'll need the remote buttons...
AndrzejM 01-10-2013 06:58 AM
IMHO it's better to use EXT button and some buttons that will fit the place you want to put them best.
