Mpguino code (for arduino)
Hi there,
I recently got my MPGuino from Meelis and i am really enjoying it. I also do some work with the OpenEnergyMonitor project (just search that and you will find the website) which is mainly focused in measuring electricity and gas consumption and temperature. They have developed a brilliant tool for visualizing the data called emonCMS. But having said that in the OpenEnergyMonitor we miss something as important as fuel consumption and that's why i am here now :-) What I want to do is integrate mpguino with emonCMS, how:
About the app: I am already playing with it but may take a while. About the hardware: I have worked before with Arduino and feel confident adding the BT module but before starting with the breadboard I want to check something with the community knowledge:
About the firmware, basically the same issues than with the hardaware:
Sorry, lots of questions, but any answer will be most apreciated carlos |
I would say to stick with the official v0.86 version .pde file, and update modifications to that. But it's up to you.
That code still works great with Arduino framework, only difference is the 20MHz crystal. That v0.97 by Meelis is maybe just his own numbering from that 0.86 code. But you gotta ask him yourself. What i do is just "based on version v0.86 by dcb", with following feature list whick i think is most clearest. By using the official schematic, you are not going to lose about anything. Spare pins are thing that you may want to add, so you can later make modifications easier. I have made my board full of spare pins and pads as you see (RX/TX/analog..): http://mthtek.com/images/auto/mpguin...Guino-v1.1.jpg But good idea for you :) |
Thank you very much Quezacotl,
I hope to have the chance today to have a look at the schematic but to start with it sonds good do you have kept pins available. Thank you as well for the tips about the code, now i will have a look at it properly as well. I´ll keep the forum updated with any development. |
