EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   MPGuino and Coolant temp sensor signal (https://ecomodder.com/forum/showthread.php/mpguino-coolant-temp-sensor-signal-14557.html)
meelis11 09-15-2010 03:21 AM
Hi,
I would like to see coolant temperature on MPGuino but I dont know how to connect it to MPGuino.
Has anybody done it? Schematic/sketch would be nice
I know that coolant temperature sensor varies resistance and ecu sends 5V into it.
I measured it some time ago, some example measures:
* outside temp 18C, engine not started = 2960 ohms.
* warm engine (ca. 90C) = 170 ohms
* 4 hours later 1325 ohms
dcb 09-15-2010 07:18 AM
Can you measure the voltage on the sensor? It is probably part of a voltage divider circuit, and if it is putting out in the range of 0-5 volts then it is suitable to be read by an atmega without extra circuitry.
The next problem of course is adding some code to read it and display it.
meelis11 09-15-2010 07:58 AM
I think it is powered with 5V but I better measure it.
So if it is 0-5V then I can just attach wire to sensor wire and other end to ATmega pin?
dcb 09-15-2010 08:09 AM
That's the idea. Of course no guarantees, but atmegas are only a couple bucks.
NachtRitter 09-15-2010 01:06 PM
Similar setup in my VX; Interested in doing the same thing. I can do a direct connect, but anything outside of that is a mystifying to me.
dcb 09-15-2010 01:11 PM
I mapped out a map sensor connected to an atmega over here, fyi
http://ecomodder.com/forum/showthrea...nsor-5208.html
might be more useful than temp, or offer some thoughts on temp anyway.
NachtRitter 09-15-2010 01:20 PM
Interesting, and thank you
