Mud Flaps
I am pretty sure I am going to remove my flaps. Soon look at how much they scoop inward. [IMG]http://i292.photobucket.com/albums/m...hrisCar009.jpg[/IMG] I have not even finished my first tank infact I have only drove 20miles so far. Obviously still at full. I dont really care how much each item or project I do gives me as long as I get good numbers. I am currently still doing city driving which I believe the flaps want come in to play until I start my highway driving. I don't care if I only get 5 miles improvement on the whole tank. I'll post pictures if I do soon... Before and afters. Input or just comments about mud flaps would be great.
Thanks all and keep on rockin those high numbers. :cool: |
Hurry! Get rid of them.
I had a similar set on my Integra -- big scoops. I found when I took off the rear flaps, it left a big hole from the wheel-well back to the bumper (which looked worse, aerodyamically). On the non-muffler side, I placed a pan to direct the air under the bumper. The muffler side was a bit more challenging -- a combination of bending the heat shield and other parts helped with the flow.
Every little bit helps! Welcome, BTW. Is Triad near Raleigh/Durham (my employer is HQ'd in "RTP"). RH77 |
That scoop is tiny
I would just leave them, or trim off the scoop part.
When I took mine off (the rear wheel), they left a big gap, so I cut them down and put them back on. The front ones I ditched completely. http://ecomodder.com/forum/36034-post25.html |
My Civic has the same gap. Yea good thinking with the triming. I will have to make something to fix that gap. This may sound dumb but what about making a cut in the rear bumper to help funnel the air out. Like speed holes, or devise some kind of foam filled cover piece. Not sure if anyone has tried either. |
I too have a background in EMT/Fire (volunteer, paid service, and in-house Trauma Center). I moved into medical research about 10 years ago and it's what I've done since. I've moonlighted in CPR instruction now and then too. Quote:
I'll see if I can get some pics (if not, I'll try for tomorrow)... RH77 |
Once I checked it out, I found that only the bottom segment would be suitable for cutting open (or clean off). Since the upper half has the steel bumper and foam behind it.Plus, if I did cut it, there are wires and stuff that would have to be re-arranged. I think boxing in that void area with coroplas or sheet metal wouldn't require a lot of work and might be the best way to do it. http://i46.photobucket.com/albums/f1.../blocktail.jpg |
Yeah that would proably work. Where can you get coroplast at? I have never had a use for it before.
