My 95 Thunderbird.
No, it is not an eco car per say....but it is one of my other cars.
Some on here were asking to see some pics of it and another car I have...so, here it is. Well, it is a 1995 Thunderbird. It used to be my daily driver, it had a 4.6L with a 75 dry shot of nitrous. Back then at its current weight of 3,940 lbs, it ran a best of 14.15 @96 mph, while cutting 1.99 60's on street tires. Here are a couple pics of before.... http://www.mustangmods.com/ims/u/3193/7174/211397.jpg http://img365.imageshack.us/img365/5046/dsds9yz.png Well, after running nitrous to long untuned, it got the best of my engine. So, out came the 4.6 and in went a 351W and a C6 tranny. Install was pretty fun. Since no one makes aftermarket stuff for birds, I had to custom make a few things to get stuff to fit right. First off, to get the engine to fit, I had to cut the rear of the k-member to get the 7 quart moroso pan to fit. Next, to get any kind of header to fit, I had to make my own steering shaft... http://www.mustangmods.com/ims/u/1189/1694/246973.jpg Had to bend my longtubes a bit to make em fit around the C6 tranny... http://www.mustangmods.com/ims/u/1189/1694/93692.jpg Still use the OEM in-tank fuel pump for now....but added a low pressure return style FPR... http://www.mustangmods.com/ims/u/1189/1694/105362.jpg throttle cable and bracket... http://www.mustangmods.com/ims/u/1189/1694/247399.jpg water pump and pulley setup.. http://www.mustangmods.com/ims/u/1189/1694/244134.jpg New aluminum radiator and 2- 14 inch electric fans... http://www.mustangmods.com/ims/u/3193/7174/121730.jpg http://www.mustangmods.com/ims/u/3193/7174/121731.jpg |
And here is a whole engine shot...
http://www.mustangmods.com/ims/u/3193/7174/227872.jpg Interior is pretty much gutted... http://www.mustangmods.com/ims/u/1189/1694/119246.jpg http://www.mustangmods.com/ims/u/1189/1694/119247.jpg http://www.mustangmods.com/ims/u/1189/1694/119250.jpg sheet aluminum door panels.. http://www.mustangmods.com/ims/u/1189/1694/209209.jpg Exterior is basically stock, I run factory spare wheels up fromt with 165R 15's on them. and Out back are stock t-bird fan blades with 26x8.5x15 slicks. http://www.mustangmods.com/ims/u/3193/7174/227873.jpg track pics.. http://i295.photobucket.com/albums/m...d/DSC_0329.jpg http://i295.photobucket.com/albums/m...d/DSC_0334.jpg I'm sure I've left something out, but here is a rundown of my mods... Still running stock heads, cam, and intake 351W from an 85 F150. Edelbrock 600cfm Carb. Mallory Unilte Dizzy MSD TFI coil. Accel wires. 1 5/8 Longtubes 2 1/2" exhuast(about 12 inches) into dumped Edelbrock mufflers. 2" carb spacer Electric water pump 4:10 track lock rear MT 26x8.5x15" slicks. More weight removal....car is now down to 2,960 lbs. suspension....up front is QA1 coilovers, speacially made for the car(which means $$$$$$). They are 12 way adjustable 90/10 with 325 lb springs. out back are OEM springs with 2 coils cut on each spring. also, still run the stock IRS. It ran a best of 13.85 @96.42 mph w/ a best 60' @ 1.88, and best 1/8 was 8.79 @ 78.33 mph. time slips.... http://www.mustangmods.com/ims/u/3193/7174/233508.jpg |
AWESOME pics tbird! you really do pay attention to detail! That steering job you did looked pretty impressive.
Thanks man, it means a lot.
Nice car! I think you did a very nice job on it!
very nice, the best thing ya did was ditch that computer controlled smog equipment choked 5.0 :)
I *personally* would love to swap a 32v motor and 6 speed into a '12th' gen bird. Im just not an old pushrod/carb guy I guess.
No but yeah I have seen a couple.
