My Continental Contact-Pro Tires
Hello -
I just got these Continental Contact-Pro tires around June 3rd, 2007 : http://ecomodder.com/forum/member-cf...taltirepu7.jpg http://ecomodder.com/forum/member-cf...altreadkf4.jpg New tire size : 195/65 R15 Stock tire size : 185/65 R15 Here are some specs on the tire : ContiProContact http://www.tirerack.com/tires/Spec.j...irePageLocQty= Code:
Size = 195/65HR15 I used this site to figure out my difference in speedometer readings : Miata.net Tire Size Calculator http://www.miata.net/garage/tirecalc.html It told me that the speed will read 2.1% too slow. I don't use my ScanGauge for my mile/distance readings, I use my car odometer with a GPS correction. Here are the two GPS correction tests I have done using my wife's eTrex GPS : Code:
Car Odometer GPS GPS/ODO % Correction The only problem is that on freeways that are grooved in the direction I am traveling, the car "wiggles", aka the tread tracks into the grooves like a phonograph needle and the car has a noticeable wiggle. I had a feeling this might happen, but no proof until after I bought the tires. Thank goodness my main commute only has this for maybe a mile or two. My wife's new GoodYear Eagle GT's do the same thing to a lesser extent. Back in the day it was MUCH worse on my motorcycle, CarloSW2 |
I used to have the Eagle GT's on a '90 Beretta. Brand new, they hyroplaned like crazy (stuck to the road pretty well, though). With the higher pressures on my Michelins, the biggest difference is cross-wind stability. It takes a bit more steering feedback to keep it straight. Yeah, Kansas City has a higher wind speed average than Chicago (the "Windy City"). RH77 |
RH77 -
LOW ROLLING RESISTANCE TIRES - March 2003 - Page 5 http://www.greenseal.org/resources/r...resistance.pdf Code:
BRAND = Continental ContiTouring Contact http://ecomodder.com/forum/member-cf...ch95-ci2-l.jpg My tires are not an exact match, but they have the same "pedigree" (fingers crossed :o ). I didn't get the tires from the GreenSeal document because I could not get the size I wanted that was also rated at 51 PSI, :( . CarloSW2 |
That's a good value vs. RR. I think you'll find the treads a fine addtion to the Sat. Plus, the 51 psi certified max PSI is an added assurance.
As for the circumference, an adjustment to the SG may be necessary -- not a big deal. I usually have mine set to the most pessimistic settings so I try harder. The displayed FE prompts additional effort if it's perceived as low. The trick is to disregard the setting and shoot for that higher goal. Hopefully, I'll have 2 record tanks through this and lower cruise speed. Let us know how the new tires work out! :thumbup: RH77 |
RH77 -
I will be doing a GPS adjustment in the next few weeks, so I will add the results to the thread. CarloSW2 |
Hello -
I just did another GPS correction test : Code:
Car Odometer GPS GPS/ODO % Correction In the 2008/10/09 test, I was much more careful. I *like* that the % is going down over time. This is consistent with tread wear. As stated before, I am sticking with a 2% error correction on my gaslog because I don't want to accidentally inflate (ha ha) my MPG numbers. Also, tire wear will eventually bring this correction down over time (i.e. always losing tread => always reducing tire circumference => always reducing odometer error over time). Me happy, :) . CarloSW2 |
So the Odometer quits when the key is out? Weird -- I didn't know that some cars did this. It makes sense if the intention is to tow the car behind a motorhome as many Saturns are designed to do. RH77 |
Hello -
Car Odometer GPS GPS/ODO % Correction I just got the tires rotated and they didn't say there were any wear problems. When I get the rotation I drop the PSI to 42 to avoid lectures, and fill 'em back up to 50 PSI afterwards. Me still happy, :) . CarloSW2 |
Old Tele man -
Your Eagle RS-A's : http://www.tirerack.com/images/tires...a_bw_ci1_l.jpg My ContiProContacts : http://www.tirerack.com/images/tires...tact_ci1_l.jpg Toyota Prius Goodyear Integrities : http://www.tirerack.com/images/tires...rity_ci1_l.jpg And, I think my friends' Prius also has road wiggle. Your OEM tire is usually picked for upping MPG to increase the EPA MPG score. Maybe that's a clue that we have a tread pattern that is conducive to LRR. Hrmmmmm, this makes me wonder. If it fits, should I try Prius OEM tires next time? CarloSW2 |
