my custom CAWAI
Greetings from the Philippines!! For the past 2 days I've been searching for various in parts in doing my custom CAWAI or Cold-Air Warm-Air Intake. Having done several researches over the net Hypermilers prefer Warm Air intake (for references 65+ Vehicle modifications for better fuel economy - EcoModder.com) to improve their MPG/KML but at the expense of engine power while Cold air intake is preferred by performance tuners for extra power.
Today I tried doing the best of both worlds by doing a intake that can perform both as a CAI (on high speeds) and WAI (on low speeds) and here it is: http://i39.tinypic.com/ngygxv.jpg blue arrows - the end of this tube is directed towards the outside environment and the tube end faces and catches wind when the car moves forward red arrows - these are holes I made to the connecting pipe which hold the two hoses, the holes serve to draw in warm air form the engine bay to the carburetor which is made during idling or slow speed which I hope would provide a better FE blue-green triangle - the holes I made also serve another purpose. This is monsoon seasons and heavy rain and floods are now common. These Holes serve as a bypass when negotiating thru a flood, this prevents air being sucked up to the carb/intake and instead draws air again from the engine bay. green arrow - air going to the intake Tomorrow I'll try to post a pic with this installed on my engine. So that's it! I hope this works! I hope that somehow my FE would improve without the expense of my engine power. I'll update you guys by next weekend. Thanks in advance!!! :D :D :D :D :D :D |
Interesting idea. I would think that even at idle most of the air would be pulled through the larger opening and you would only receive slightly warmed air (mixture of the two openings). How do you plan on testing? Let us know how it works out.
In the picture it looks to be of a small diameter what car is it to be used on? |
http://i41.tinypic.com/2uo751x.jpg http://i39.tinypic.com/egeeeq.jpg |
BTW, it's monsoon season right now rain is more common on the afternoons where I usually drive home and face floods along the way, I hope by making those holes my carb won't suck in water as long the flood is not that deep.
The way the air intake system is mounted and coming across the exhaust manifold one would think you already have some benefit of preheating. Looks like part of the intake tube is wrapped with insulation?
as promised, here are the pictures of the CAWAI installed on my engine:
http://i42.tinypic.com/i78jty.jpg http://i40.tinypic.com/e8ofio.jpg This is the WAI side of my intake (note: I removed the washer reservoir to have a more better view) http://i44.tinypic.com/51dkxi.jpg This is the CAI side of my intake (note: this is located just behind the front bumper right side) http://i41.tinypic.com/o73hbo.jpg another upgrade done, my new Electronic Distributor care of Koya She of SB Salon ;) http://i40.tinypic.com/sm6nau.jpg Thanks!!! :D:D |
An electronic distributor should be more reliable than points and condenser. Looks like you have also modified the emissions system?
I the early 70's my father did some fleet testing of GM HEI distributors. One of the thing he told me was that after 60K miles they would change the plugs and performance would go down, it seemed the new plugs were not gaped wide enough to take advantage of the output. As part of the changeover to an electric distributor were you require to change the plug type or gap?
