My Grille Block with Fabric Cover
A while back I made a thread here asking about using stretchy fabric to cover the bumper. Basically, I wanted something that looked a bit more aesthetically pleasing than just cutting and drilling choroplast to the bumper. Here's how it turned out
Factory front grill http://img522.imageshack.us/img522/3782/frontgrill.jpg I wasn't sure if the fabric alone would be a good wind deterrent (I figured wind would still pass through it), so I made a grill block from choroplast. http://img36.imageshack.us/img36/225...asticcover.jpg Here's the lycra nylon I cut up http://img204.imageshack.us/img204/5566/nylonfabric.jpg Grill, block and fabric together http://img199.imageshack.us/img199/9...tandfabric.jpg All it takes is a simple stretching and wrapping the fabric around the grill clips http://img121.imageshack.us/img121/4...ndtheedges.jpg Here's how it looks! http://img683.imageshack.us/img683/734/grillid.jpg http://img717.imageshack.us/img717/1990/farshot.jpg Overhead http://img19.imageshack.us/img19/6857/topviewv.jpg From the side http://img23.imageshack.us/img23/5808/sideviewr.jpg What do you guys think? Be honest, if you don't like it that's cool. I like it because it's easy to remove if I need to, and I think it's more aesthetically pleasing than what I could do with choroplast alone. I'm going to do the whole bumper one of these days soon, but this will do for now. |
I'd say that it looks very nice. My brain is trying to ask "What about the coroplast having sharp corners and cutting the fabric? What if the fabric tears?" and I'm trying to shut it up. :)
Good creativity! I've been working on my grille block for a a couple days, and not once have I thought of fabric :)
It looks good!
If you like it enough to make it permanent, you could always cover the fabric with fiberglass resin and make it a lot harder and not worry about the fabric tearing. |
TomO -
CarloSW2 |
For non-technical applications like this where the strength of the epoxy or
polyester resin/fabric composite is not an issue, you can significantly shorten the post construction sanding/finishing time by adding a soft "filler" to the resin to more quickly cover the weave pattern in the fabric. Huh? Typically, in structural applications, the ideal resin-to-fiberglas ratio is 1:1 by weight. There a special lay-up schedules to achieve this. Usually it involves using non-woven mat between layers of woven cloth to lift the resin content, and get better cloth-to-cloth layer bonding. However, this is not the case in something needing little real strength like a grill cover. What you want in this case is a quickly/easily/inexpensively achieved surface that fully masks the weave in the cloth and be sanded smooth for finishing/painting. The answer is to fill the resin with some relatively soft material. Like what? If you have access to a West Marine or other boating supply house you could buy some "micro-balloons," incredibly small plastic spheres. But you can just as reliably use stuff around the house; very fine wood dust from sanding, baking soda, cornstarch, even plain old cooking/baking flour. First coat your fabric with coat of straight epoxy/polyester resin. You don't have to go immediately on to the next coating. Just do not let the resin fully cure. To get a chemical bond between coats, you need to apply the second coat while the first is partially cured and slightly tacky. Next thoroughly mix the two part epoxy/polyester resin in the correct proportions. Then add you thickener-of-choice to get a consistency between mayonnaise and peanut butter. Thinner mixtures will tend to level better, but are harder to sand. Thicker mixtures build faster but result in a rougher surface requiring more sanding. Brush, roll or trowel your filled resin onto the fabric base. Strive for enough thickness to allow for sanding some away to get a good smooth surface for painting. Once the coatings have cured hard, sand away to get a smooth surface with final sanding with 220 grit. Follow-up with 2 coats of primer (sand between with 320), and two coats of top coat (sand between with 400 grit). A clear topcoat is optional but desirable. Most folks don't like to hear it but the longer you let paint harden and cure in air before you put it into service the better. It wouldn't be a bad idea to let your new grill block sit in a well ventilated place for a week before mounting. Hope this helps. |
Did you give any thought to using vinyl? Just make yourself a aero "bra" that covers the grill opening instead of leaving it open as the commercial ones do. It would be more durable than fabric and the surface could be wiped off. I'm afraid any open weave fabric would get pretty stinky after a few hundred bugs smash into it.
Rokeby, super helpful info there mate. :D
