My Headlight Restoration Results
1 Attachment(s)
Hi, Sorry if I put this tread in the wrong place in the forum but I didn't know where it should go :confused:
But I saw something about restoring your head lights with toothpaste... I had a broken headlight so I figured it could not mess it up too much :) So here are my results: |
HypermilingNoob -
Cool. That's on my todo list. What brand of toothpaste did you use? I doubt if whitening matters, ;) . CarloSW2 |
How exactly do you do it?
I knew a mechanic who used toothpaste, after trying many other abrasives, to shape lenses
Nice job, subscribing. I betcha toothpaste is cheaper than the headlight restoring kit you can buy at Napa. Was a buffer used, or was this done by hand?
How And What I Used
All I did was go out there and with my hand spread toothpaste all over the head light (CREST Cavity Protection Regular Paste) then after I got it spread out evenly I got a dry cloth and wiped it all off, then washed with soap and water to get any left over residue off. Obviously it didn't make the head light crystal clear but it did help some so why not just do it?
What happened to it in the first place? I got wax on mine
becha as little water and a "micro" buffing pad would make a ton of difference cleaning them up.... but, I too would experiment on a broken headlight
kitaimdao -
CarloSW2 |
