EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   Is my math correct? (https://ecomodder.com/forum/showthread.php/my-math-correct-15951.html)
BHarvey 01-29-2011 09:36 PM
Is my math correct?
If your car at idle uses .25gph and you engine on coast for a mile downhill at a constant 60 mph, you have then used only .00416 gallons of fuel. That equates to doing this 240 times 'engine off' to save a gallon, or eternal vigilance!
Mustang Dave 01-29-2011 11:10 PM
60MPH/.25GPH = 240 MPG engine-on coasting @ 60 MPH.
Ford Man 02-01-2011 10:17 PM
If you can maintain the 60 MPH coast speed while in gear using DFCO then 0.00 gallons consumed, same as engine off coasting.:D
gascort 02-01-2011 11:32 PM
my car uses much more than that unless it's warmed up. my big EOC gains are when the car's not warmed up yet. Much less penalty for idling when warm.
04_Sentra 02-01-2011 11:38 PM
That would be a steep hill!
SentraSE-R 02-02-2011 02:36 PM
It's better to think of it in a real world drive. If you do a 10 mile drive averaging 40 mpg for 9 of those 10 miles, and incorporate that 1 mile downhill, it looks like this:
EOC
9 miles @ 40 mpg.
.025 gal/mile times 9 = .225 gal consumed for 9 miles
.225 gallons consumed for 10 miles = 44.44 mpg
NICE-on
9 miles @ 40 mpg.
.25 GPH consumed for 1/60 of an hour = .25/60 = .004167 gal.
.229167 gallons consumed for 10 miles = 43.64 mpg
At a more realistic 30 mph, the NICE-on idle usage doubles because the glide takes twice as long, and the car uses .23333 gallons for 10 miles = 42.86
