EcoModder.com
-   -   My RV a true mileage efficiency challenge (https://ecomodder.com/forum/showthread.php/my-rv-true-mileage-efficiency-challenge-26792.html)
Geocritter 08-27-2013 08:27 AM
Greetings, I’m in my mid-60’s and a life-long shade-tree mechanic doing 95% of my own car, RV, boat, motorcycle, and appliance repair. I attempt to help the environment by not needlessly replacing things when they fail.
I recently purchased a 33’ 1994 460 Ford V8 powered Holiday Rambler motorhome to both live in full time and use as a home-base while I travel this beautiful country towing my 2005 4cyl Dodge Caravan to use as an exploration/overnite camping vehicle. I’ll be driving the MH mainly on the interstates stopping for weeks and even months at a time in various national and state parks. My travels will initially be throughout the west. I expect the first “loop” will take me from San Marcos TX west to Tucson AZ and then LA followed by north Yosemite and on to Port Angeles WA and finally east through WA, ID, MT and SD. After a 2 month stopover in SD I’ll be heading south to TX, NM or AZ for the winter. Overall about 5,000 miles.
The specific information I’m looking for is how to squeeze more mpg out of my MH. I haven’t had a chance to drive it much but from researching the RV websites I figure to get about 7mpg on the interstate while towing my Caravan.
As far as background regarding the MH, it has a FI 460 Ford V8, running through a Ford E4OD 4-speed automatic transmission and a 5.13 rear axle. The unloaded vehicle weight is 13,898lbs with a total maximum gross vehicle weight of 17,000lbs. The 2005 Dodge Caravan I’ll be towing, with a tow dolly, weighs about 5,000lbs including the dolly. The MH has 58,000 miles but supposedly the engine and trans were replaced 20,000 miles ago (apparently, the previous owner was not into maintenance of any kind).
Sorry, the board won't let me post a photo, I only wanted to post so that people could see the aerodynamics of my MH, oh well...
A photo of my new home.
Any suggestions for cruising speeds. I realize that lower speeds will increase mileage but at the same time I don’t want to have to drive so slow as to antagonize other drivers (angry people do stupid unfortunate things). I know that higher tire pressures can help but there again, with the weight I’ll be carrying I don’t want to compromise safety for an extra mpg. I read through some old threads on this board where someone put plastic sheeting under their MH to decrease wind resistance, a great idea for the future, but I’m a little lite on $$$ at this time. In addition, the MH has a huge grill which I’d rather not sheet over since over-heating can be a problem on these large gasoline powered RV’s.
I’m pretty happy with my Caravan. With no AC running, it gets around 25-27mpg highway, but only about 20mpg city. I usually keep it between 65 and 70 highway, however I probably do drive a little too aggressively around town for optimum mileage. As soon as I can free up some cash I’ll be picking up a used Kawasaki KLR 250 so that I can explore with a vehicle that gets even better mileage, plus motorcycles are fun.
Steve
elhigh 08-27-2013 10:32 AM
Hi, and welcome. I reckon a moderator will be along to welcome you much more officially soon enough.
You have an uphill climb with your Rambler but it isn't a lost cause by any means.
I know you state very clearly you're happy with the Caravan, and I was happy with mine too until it puked up its own brain (long story), but it's kind of heavy. Would you be willing to switch to a smaller/lighter dinghy, perhaps something with a manual transmission? That could eliminate the need for a tow dolly.
I thought about recommending a largish scooter or a motorcycle as your exclusive dinghy, but if it rains that just stinks. Bikes are no fun in the rain. They just aren't.
Check this out: http://ecomodder.com/forum/showthrea...d-e-18151.html Forum member Orbywan has a Class C RV, a bit smaller than yours and with a turbodiesel, but he's made some serious aero mods to it and just looking quickly, I see a ~15% improvement. You could extend your aero tail, if you're inclined to make one, to shroud the nose of your dinghy and the dinghy's presence could have the effect of extending your tail even further. Some testing would be required to confirm that.
That'd be pretty cool though, if with the addition of a few aero features you could effectively negate the load of the dinghy, maybe even make further steps toward the positive. An RV that gets better mileage towing than bobtail, funny. Like I said, testing required.
cRiPpLe_rOoStEr 08-27-2013 11:15 AM
I didn't even know there were 4-pot Caravans back there for that model-year, the only ones I knew were turbodiesel available only in export markets.
Regarding the motorhome, a Diesel swap would sound as a good improvement mileage-wise, also increasing the ability to run on alternative fuels which might eventually be a great benefit on longer trips. Another issue is that they don't have too much room for improvements, altough there is always some way to get a considerable weight reduction in case of interior refurbishments.
Geocritter 08-27-2013 12:00 PM
To anyone recommending diesel power, I’d love to have diesel power, for many reasons besides increased fuel mileage. However, reality rears its ugly head in the form of $$$$ or lack of $$$$. If I were to go to diesel power it would be far simpler just to buy a used diesel powered RV. Probably won’t happen anytime soon.
The 4 cylinder Caravan is okay, however what I'm really concerned about is the 7mpg RV. As far as the Caravan's concerned, though it’s rated at 150hp it doesn’t have the torque of a V6 with equivalent hp. I had a 1998 Caravan with a 150 hp V6 and it actually got slightly better gas mileage than this 4 cylinder does. I really liked that V6 Caravan, but with 286K on the odometer, a bad AT and a leaking condenser on the AC it was time to sell it. It still ran great, if it were just the AT I probably would’ve fixed it, but with the bad AC and living in Houston at the time, it was time to say byebye.
I’ve thought of selling the Caravan but it’s so nice to live in while exploring the countryside, I hate to give that up. I wish it had a standard transmission, but I doubt if they were even made for the car.
Steve
cRiPpLe_rOoStEr 08-27-2013 12:16 PM
It might not be so hard to find a suitable transmission from Mitsubishi or Hyundai.
elhigh 08-27-2013 01:32 PM
Steve
I had a '91 Caravan with almost no bells or whistles. My wife and I immediately added seat covers (homebrew from southwestern style throw blankets) and completely covered the interior carpets with seamless denim from front to back. When it came time to sell the car, we removed these interior treatments and the van looked like it had never been ridden in.
The exterior, however, was graced - temporarily - with factory Dodge paint that didn't adhere to anything but the wind with any kind of tenacity. Giant, hand-sized flakes would peel off. We painted the vehicle with strange designs. My niece painted a huge bare-breasted mermaid on the roof. We asked her if the mermaid wouldn't distract the truckers too much.
"They're grownups," she said. "They can handle it."
Turned out the kids in the school buses were a bit more impressionable. Oops!
Anyway. Yeah, for exploring the Caravan is tough to beat. With a custom tent to go over the liftgate, you can use it as a bare-bones RV in its own right. We covered a lot of miles in ours.
mozul 08-27-2013 02:20 PM
I have a 32 foot RV with a V10 Ford engine in it and get a similar mileage 8 or so. You can use many of the hypermiling techniques with the RV to help. Put it in neutral on slight downgrades where you won't gain too much speed. Pulse and Glide will help you too. On big downgrades you will still need to put it in gear to keep the speed down. Keep your speed down. 55 is plenty. I am in California and am limited to that while towing. I don't see any mileage change whether I am towing a vehicle or not. However, bringing the tow vehicle along saves gas a lot since you drive the RV only between campsites and you drive the more efficient tow vehicle to see the sights.
Also, get a mileage computer, ScanGauge or Ultragauge. That will help you with your technique.
Have fun!
Geocritter 08-27-2013 02:27 PM
I too had a 1991 Caravan, mine too lost its paint. I bought it used and owned it from 1993 until 2000 and by the time I sold it the van had 251K on it. It was not nearly as good as the 1998 and 2005 Caravans I’ve owned, I was constantly having to do mechanical repairs to it, but I also took my two kids on a lot of outdoor adventures in the thing. My late wife’s idea of camping was staying at a Super 8. However, my adventures with the kids gave her much needed time to herself. I took out the rear seats and put in a 1’ high by 4’X6’ floored area in the back (I’m doing the same with my current Caravan). We’d stow our gear underneath and the kids would play in the back while we traveled (no seat belts back there, but somehow we survived). At night we’d usually sleep in a tent, but if the weather was real bad we’d crowd into the Caravan and sleep in it. As crappy as it was, that 1991 Caravan made great memories my adult kids still talk about. Like all my Caravans it got around 26mpg highway.
Steve
elhigh 08-27-2013 04:23 PM
Yup, that's what we did too, or nearly. We built a platform to rest on the folded-down wayback, and that doubled as a bed (with an anti-tumble guardrail) for our kids, about 2 and 4 years old at the time.
The wife and I slept in sleeping bags on the ground under the tent, the floor of which wasn't attached on our first trip. Raccoons came under the edges, and then when we got home we attached the floor to the walls.
Ah, good times.
UltArc 08-27-2013 05:15 PM
The impression I am getting is that you want mods that will pay for themselves pretty quickly- so either super cheap mods, or super effective.
Some things that are dirt cheap, easy, and should make a difference...
-Deleting things that aren't needed
--take off a mirror if you don't need it, antennas, roof racks
-Smooth wheel covers (election signs)
-Rear arch covers (election signs)
-Dropping unneeded weight (Do you have things you don't need?)
--For example, if you had a granite countertop, is it worth the extra weight verse a basic plastic?
-Grille block (or partial- either way, easy to remove)
-Partial underbody
-streamline your vehicle into the trailer/caravan (would be more costly)
-Test pulling the caravan flat vs on the trailer. Better or worse?
-Warm Air Intake
-DEFINITELY an air dam
-start switching fluids to synthetic
One fantasy I have is an MP5 (or MPV) in a standard, setup to road trip in. You'd have a standard, could pull flat, and they are pretty cheap relative to other vans in its class. Another alternative is a estate. On past road trips, three of us have slept in a coupe (2002 Monte Carlo) over several nights. If you want more comfort, an estate would work great. Not hard to find a standard, better aero, would meet the needs you have shown so far. What comes to mind is the Subaru Outback/Legacy estate- which can be found pretty cheap (as low as 1,600 USD).
Just some ideas.
