EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   my TIGRA AERO PROJECT (https://ecomodder.com/forum/showthread.php/my-tigra-aero-project-1522.html)
fabrio. 03-23-2008 01:03 PM
ok boys.
I go to to describe the work on my car.
First, the car is an Opel tigra, year 1996
It is a little coupè, wit only 1604mm of length.
this is a profile of original car
http://img257.imageshack.us/img257/6914/tigralj4.jpg
and this below, it is the final solution (without the wheels), but my girlfriends does not want :(
http://img177.imageshack.us/img177/5007/provaxk6.jpg
My mods include:
1) ugly rear underbody extractor
2) fuel tank area covered with polycarbonate ( the exahust line is not covered)
3) front and rear wheel air deflector: the front deflector, deviate the airflow over the horizontal arm
4) grill block: this use three guideline bearing with manual positioning.
5) I do not know what name to give him, I call it: wheel flow stabilizer (WFS).
I is necessary to study it for a good performance.
A lot problem, it come from the rear suspension axle becouse it is exposed to airflow; I have an idea for problem resolution, but any advice is appreciated ;)
Other problem come from the engine undercover not present.
below some pictures:
first three pictures refers at original car (rear car)
http://img214.imageshack.us/img214/8808/pontent7.jpg
http://img214.imageshack.us/img214/9016/sxyr5.jpg
http://img214.imageshack.us/img214/3817/dxek8.jpg
now, the pannellings of previus pictures
I have pan all fuel tank area
http://img242.imageshack.us/img242/5074/f1as3.jpg
http://img165.imageshack.us/img165/4736/f2rv0.jpg
http://img165.imageshack.us/img165/2090/f3yf4.jpg
in this pic, you can look the marked areas covered
http://img161.imageshack.us/img161/9526/tigrafpsp0.jpg
Down, the ugly rear extractor
http://img112.imageshack.us/img112/57/scivolods0.jpg
http://img112.imageshack.us/img112/336/retrohb2.jpg
the points of anchor :
http://img112.imageshack.us/img112/1...oraggioef8.jpg
from the front:
original
http://img66.imageshack.us/img66/2451/fobx4.jpg
http://img66.imageshack.us/img66/806/fo2cv3.jpg
http://img59.imageshack.us/img59/7894/f2gj3.jpg
http://img59.imageshack.us/img59/3038/fronthm0.jpg
http://img59.imageshack.us/img59/1529/profilolo7.jpg
the plastic elements come from this:
http://img490.imageshack.us/img490/3...viatorisa0.jpg
http://img116.imageshack.us/img116/5404/totalpp4.jpg
in detail:
http://img116.imageshack.us/img116/478/f2tx5.jpg
the FWS
note: final pictures are not available.
http://img220.imageshack.us/img220/5686/p1010609ga6.jpg
http://img228.imageshack.us/img228/4527/p1010608dc0.jpg
In red , the final profile
http://img443.imageshack.us/img443/7979/profilozc3.jpg
the idea came from looking the underbody airflow of mercedess SLR
Note the air flow in to the rear wheel, wich cause turbolence (in the slr the flow it is used for brake ventilation)
http://img230.imageshack.us/img230/9...rtotammar6.jpg
My friend has an engine undercover Audi, but I discovered it :(
http://img407.imageshack.us/img407/5...2007001ql9.jpg
when this cover is applied to the original bumper, the result like below:
http://img150.imageshack.us/img150/5...2007012jk3.jpg
http://img358.imageshack.us/img358/7537/27926050mq9.jpg
fabrio. 03-23-2008 01:13 PM
more informations at http://tigrafans.forumcommunity.net/?t=7378938&st=0
Cd 03-23-2008 01:13 PM
Looks like you are off to a great start.
Looking forward to your results.
How are you keeping track of your fuel mileage ? Do you have a Scanguage ?
fabrio. 03-23-2008 01:20 PM
this is the biggest problem: i do not have any fuel meters.
Thi is for me an atypical case: I am generally precise and meticulous, and for engine mods Always I use the tools needed , but in this case...:(
fabrio. 03-23-2008 02:16 PM
the grill block :
I have used, PVC element for the block, and three sliding guide anchored to the front frame.
http://img210.imageshack.us/img210/813/p1010660fb6.jpg
http://img151.imageshack.us/img151/1521/p1010662bt5.jpg
http://img249.imageshack.us/img249/3408/p1010661oh5.jpg
http://img232.imageshack.us/img232/3726/p1010670su4.jpg
http://img405.imageshack.us/img405/4214/p1010664yf1.jpg
in the future I will use an electric motor for management grill block opening, or I replacement him with other mechanisme.
an other mod is the replacement of the original windscreen wiper
http://uploads.forumcommunity.it/pos...1176658289.jpg
http://www.bosch.it/formula/archivio...ages/spaz2.jpg
SVOboy 03-24-2008 03:14 AM
Wow, this is a great thread! Keep up the good work...that's a really nice looking car, too!
Daox 03-24-2008 08:43 AM
What is the original Cd of the car?
johnpr 03-24-2008 10:54 AM
nice car, looks like some good mods
fabrio. 03-24-2008 02:30 PM
Coefficient of drag: 0.31
Frontal area: 19.16 sq.ft.
I have a little simulation: max speed Vs Cx (Cd)
[IMG]http://img291.imageshack.us/img291/2593/velvscxfn7.jpg[/IMG]
Two engine: in red the the 1.6liters with 100Hp , and blue, it is the 1,4 liters and 86Hp, both engine, with 16 valves.
MetroMPG 03-24-2008 11:06 PM
Very interesting car!
I like the sliding grille block & undertray. Nice work.
