My try at a partial grill block
Since from what Ive read, Dodge shadows and plymouth sundances have pretty bad aerodynamics, 0.42 drag coefficient from most sources, I decided to try a partial grill block. Im kinda wary of blocking everything due to engine overheating.
http://img.photobucket.com/albums/v2...4/IMG_0597.jpg http://img.photobucket.com/albums/v2...4/IMG_0598.jpg The plastic is plastic wrap from a delicious Digiorno stuffed crust pizza. It seems fairly durable. I taped in on with clear packing tape. I then moved the front license plate up to the other side of the grill, need to get another ziptie for it. Depending on how hot it runs I may block more of the grill. I also have that bottom opening to work with, though that may someday provide airflow for an intercooler. |
Your paint looks really good for your car's age so I would be worried about vibrations of the license plate eating away at your paint. Maybe the soft side of velcro or something to cushion it.:thumbup:
The clear plastic is an easy solution. I did the same with my front plate :p
I'm having trouble fabricating something for mine (I just have the area similar to the bottom of your Shadow). Turns out, I can't fabricate crap. The plate provided a middle 1/3 grille block. :thumbup: RH77 |
clear to me is the way to go! stretch it good and it looks almost like it's not there!
I used plexiglass on mine. It was 10 for the sheet size I needed at Home Depot. It works and looks great. You have a easy shape to cut so it shouldn't be that bad.
i have a 92 3.0 5sp to do ,,i may be able to block the whole grill and pull air from the lower facia ,,looking at a fan up-grade maybe to :thumbup:
bhazard's grille block
bhazard, at Cd0.42, the Shadow's got a lower Cd than what Corvette's had when I was in college.Your slow approach will protect that Mopar powertrain from Btu overload.Good engineering!
I just completely covered the grill on my Shadow with duct tape. Then I spray painted it to match.
The whole car is Rustoleum Metallic Blue anyways, so the color matches perfect. No problems what-so-ever with that. When I stuck some coroplast down the front, I DID have to cut some slots in it to keep the car at the right temperature. Now if only there is something I could do about the crappy 3-speed automatic transmission. |
Well, the car was just over 3/4 tank and I topped it off. Tripmeter showed 101mi, multiply by 1.036 to correct it for oversized tires and get 104.636mi. Divide by 2.74 gallons which is where the pump shut off and I got 38.188 mpg. What? Can a partial grill block seriously give you 10 mpg?
Im skeptical, I dont think Im gonna enter this into the fuel log. Ill run it down a bit and do a real fillup first and see. The leaky transmission was also a quart and a half low on fluid so that makes things even harder to believe. |
yes, I low fluid=less pickup and power. so more losses at the drivetrain. also have the slipping problem in cold weather.
