NarrowerTires?
I have an '09 Focus that is giving pretty good FE. The tires on it are in good shape with only ~22k miles. It will be awhile before I need to look for new shoes but in thinking of ways to improve economy, I was thinking of switching out to some narrower tires when the time comes.
The stock tires are a 195/60-15. I found a 155/80-15 that looks to be within 2% of the stock diameter so it should work without effecting gearing or the odometer/speedo. The only negatives I can think of is the ride will be harsher and to avoid cornering at high speed with the effective higher profile to width ratio. In the realm of safety, seems like it should be fine? Any thoughts or advice on what I may be missing? Doug |
I think rolling resistance won't be lowered unless you run them with much higher pressure than stockers. But then, you could just as well pump up the stockers.
Hmmm, that is surprising. I would expect a width difference from 195 to 155 would be notable or significant effect on reducing rolling resistance?
Doug |
Depends on the loads the tire sees.
There will be a small but real aerodynamic benefit from going with narrower tires as well.
See this BMW data: http://ecomodder.com/forum/showthrea...g-cd-7475.html Will 155's fit properly on the rims (width)? In "the realm of safety", as you put it, I expect you'll likely see reduced lateral grip in the dry (not certain about wet - depends on many other factors). Whether you're OK with that is up to you. |
Potentially braking traction will be affected as well. Not definitely, as other factors will have an influence.
I went from 195 to 185 width on my CRX. The difference seems to be "in the noise". -soD |
I went from 185s to 155s on the Paseo. The change was noticeable at low speeds.
The change of what?
I could noticably coast farther after 'the change' of tires/rims.
First, a 155/80R15 83S is 4 load indices lower in load carrying capacity. That means that all other things being equal, you will need to use 4 psi more than what is on the vehicle tire placard for comparison purposes. According to Tire Guides, a book that summarizes vehicle tire placards, a 2009 Ford Focus with P195/60R15 87T's should have a tire placard that says to use 32 psi. Please check the vehicle placard to see if that is correct. What this means is that even if you inflate the tires to the maximum, the tire has less load carrying capacity than the original tires. Not only is that going to hurt the fuel economy, but it's a safety issue, too. Less load carrying capacity increases the risk of a load related tire failure, which sometimes has tragic results. PLUS, going down in speed rating (T to S) is also the wrong way with regard to safety. While the amount of tread rubber is important, there are 2 other considerations for a tire's contribution to fuel economy: The rubber, and the amount of deflection. As I pointed out above, the lower load carrying capacity means more deflection and worse fuel economy - all other things being equal. The type of rubber is very important - and probably the most important thing. Tires designed for good fuel economy (like what came OE on your Focus), are going to use types of rubber compounds that give good fuel economy. That is generally at the expensive of traction (especially wet traction) and tread wear (or both!) Going narrower also means a smaller footprint, and that has implications for traction. So while going narrower may seem like a good idea, there's a lot of down sides to this. It has to be done carefully - which why you asked the question, isn't it! |
Skinny 165/80R13 on the back (185/75R14 on front) :
http://i146.photobucket.com/albums/r...encher/017.jpg Got a decent pair off a Metro and put 'em on Tempo rims. No testing or even impressions yet. |
As to the earlier comment on rims, yes, I would have to purchase narrower rims to go down to this width. I was looking at some cheap steel rims with some possible moon covers. Doug |
I rarely have back seat passengers or even a really heavy load in the trunk. The rear of fwd cars typically carries 1/3 the weight. If it doesn't see max loads I don't think safety is compromised.
There are several formulae for calculating the load carrying of a tire, but they are complex - and of course, it varies accoprding to inflation pressure. Usually load carrying capacity is published in the form of a table. I explain that in more detail here: Barry's Tire Tech Quote:
IF loads are light enough to safely use a smaller tire the gain is in the thinner rubber and fewer belts. And as noted if you can air them up enough so that they aren't suffering increased deflection vs original. I doubt going bigger/stronger than stock results in lower r.r.
http://www.energy.ca.gov/transportat...%20Testing.pdf you'll find that RRC is slightly better for larger capacity tires. (pg 31) So going larger than stock is directionally better for fuel economy, and using a tire that can barely carry the load is not the best move to make. |
It's a coefficient; just like drag coefficient, the load (area for aero) must be accounted for. It's pretty well shown on pg 38 with the 15" and 17" examples: while the 17" shows a LOWER COEFFICIENT in the best case scenario vs the 15", clearly the actual rolling FORCES for the 17" are worse than the 15"; in fact the worst 15" value is better than the best 17" value! :eek:
Pg 24 shows that the heavier the tire, the higher the r.r. force; shown even more graphically on pgs 30 and 32. Pg 31 shows coefficients with the big tires outperforming the small. Yup, big ones do better at high loads. The empty light end of my car isn't subject to high loads. I did not expect to see r.r. increase with increased diameter! :eek: Unfortunately I did not see much useful info relating to width except for what may or may not can be read into pg 30 results. |
It's easy to get confused in this report because Bruce goes back and forth between RRF and RRC. The situation we are discussing is changing a tire on a vehicle so the load is basically the same. So looking at page 38, there are some 17" tires with lower RRC's than 15" tires, so it is possible to get better RRF by making a switch from 15" to 17". (Discounting the fact that the 2 tires mentioned in the report are just not interchangeable.) Quote:
Certainly, pg 24 (where the tires are the same size), a heavier tire would generally have a lower RRF and lower RRC (same load), but notice how much scatter there is to the data. It's only a 20% R squared value - That's TERRIBLE!!! This makes sense if we consider that the rubber compound has a HUGE effect. And different rubber compounds are pretty close to the same density. But pg 30 and pg 32 are about RRF and not RRC. Quote:
So if we keep the same load, a larger tire with out perform a smaller tire. Quote:
But again don't confuse RRF with RRC. While page 38 says the correlation between diameter and RRF is 76%, RRC is only correlated 56%. That's the best value, but it is not very good! Quote:
Trying to apply this report to the situation under discussion (changing tires on a given vehicle), the gist is that larger capacity is better. Trying to compare other parameters (such as width or diameter) gets confounded with load capacity. But there is a lot of variability - meaning a particular combination might not result in an improvment. So while the data indicates that a larger tire will be directionally better for fuel economy, don't expect it to work every time. |
narrow
I caught this thread but am away from home and library.I'll throw out some things,hope they're correct,verify once back home,and be back.
Many of the low-drag high mpg concept cars incorporated narrow,large diameter,elliptical,low aspect ratio,high-pressure radials,with tread designs which had all individual tread blocks,designed for low squirm,and total absence of "quiet-bands" which,while reducing tire noise,do so at the expense of higher drag.These tires were compounded for high-hysteresis and may have traded low-R-R for both dry and wet traction.Some of these tires were also designed for run-flat capability which would allow the automaker to delete the spare tire as a weight-saving technique for better urban mpg. The FORD Probe-IV had 155 size tires specifically to reduce aerodynamic drag by virtue of their 10% reduced frontal area,compared to conventional radials of that period. Many reports on the development of particular vehicles will sight the variance in Cd as a function of tire width.There is a definite correlation,there has to be,as drag is an arithmetic function of CdA. And while I believe modders are more attuned to the safety ramifications of diverging from O.E.M.spec equipment and will attempt to compensate with driving style and technique,the automaker must design for those compelled to have their Darwinian moment. I consider my own driving to be very conservative and I don't consciously desire to pose a threat to myself or innocents around me,and strive not to be "blinded" by mpg "euphoria"and inadvertantly do something really stupid and dangerous in the name of better mpg. Always think safety. |
