Old 05-08-2017, 07:49 PM   #1 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Another Step Towards All of Us Driving E-Cars....Don't Buy GigaFactory Stock Yet.
Found THIS hot article today in Science Daily. Golly, it sounds impressive, I've always wondered why we need Tootsie Roll sized batteries and have to weld em all up. The article describes how a German company is figuring out how to make batteries that are sheets instead of tubes.
Old 05-08-2017, 08:34 PM   #2 (permalink)
My now obsolete AMP20 LiFePO4 cells are flat like sheets.
Then let me guess they want to roll the sheets into cylinders too?
Old 05-08-2017, 09:55 PM   #3 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Affordability, I would presume. It was a lot easier/cheaper to start building Teslas with off-the-shelf batteries than to spend $$ reinventing the wheel.
I'm a bit surprised they're still doing it the same way after all this time.
Old 05-08-2017, 10:54 PM   #4 (permalink)
Growin a stash
There are some other considerations. Cooling channels and structural rigidity, off the top of my head.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
Old 05-09-2017, 08:37 AM   #5 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
AGM-batteries are basically sheets rolled up.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 05-09-2017, 12:42 PM   #6 (permalink)
Tesla may stick with the small cylindrical cells because of cooling.
Making a huge solid block of lithium batter would be great for power density but there would also be no way to cool it.
Old 05-09-2017, 01:17 PM   #7 (permalink)
The Volt has flat cells. It has cooling plates that go between them for thermal management.
Old 05-09-2017, 01:55 PM   #8 (permalink)
If the cooling plates are so great then why doesn't tesla use them?
Knowing chevy they will start leaking after about 10 to 15 years.
Old 05-09-2017, 02:56 PM   #9 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
LE Focus - '05 Ford Focus
Considering the charge and discharge rate of the batteries I really don't understand why they didn't add capacitors to take up a lot of the work from the batteries while driving!?!
Old 05-09-2017, 03:17 PM   #10 (permalink)
The volume isnt the problem. The problem is weight, making the batteries take up less volume wont help. EV's are typically weigh 500kg-1000kg more than gas counterparts so adding more weight isnt an option.
