New car- Project T-D-I-C (Volvo 760)
1 Attachment(s)
I gotcha m'self a new project! :D
A 1989, Volvo 760 Turbo Diesel Intercooler- Manual :thumbup: It had 470,000 kms on the odo, and i bought it because it was a semi-ok steal. The plan is to reregister it to a van by removing the rear seats in order to have a hugely smaller diesel tax (now its about 700usd a year, vs it will be 400usd or so after reregistration) later it's Volkswagen straight-six turbo intercooled ICE will be swapped for some weird audi 5-pot diesel... some say for economy, some say for 50% increase in horsepower :rolleyes: http://ecomodder.com/forum/attachmen...0&d=1506857022 |
The engine is a 2,4 truck diesel from volkswagen, used in the light truck/van Volskwagen LT... volvo used it too
Mah friend fixed the clutch, now it shifts smoothly. (for now, the wire-clutched transmission will be thrown in the dumpster once he new engine goes in with a newer box, that is also a hydraulic clutch.
now we swapped better seats in.
I have only driven one 760 sedan, it was with the 2.8v6 engine+automatic, chugging around 15L/100km :D
Was planning on buying a 700-series diesel once but at the time they were overpriced for my taste :rolleyes: Good cars, however :thumbup: |
yeah, this feel sturdy even if it's neglected a bit. It seems it has a LSD. it's an ex-nivomat, after all.
Clutch... seats... things are moving fast. It sounds like a VW motor in a 'bank vault'.
I also got a diesel recently, it's ten years older, non-turbo, but I like it. First thing I did was fold the rear seat so I can sleep in the back, but the bottom cushion folded up against the back of the front seats makes it hard to get out the front, and there is no inner hatch release. I want to pull the whole seat and make a flat platform. Swing-door material (aluminum-skinned plywood) is $100 per sheet; maybe I can find a use (box van) swing-door. |
IIRC its engine was still indirect-injection, good for some experiences with waste vegetable oils as an alternate fuel.
Now it has a exhaust :D a bit closer to completion.
Also, we'll get better springs (cut springs right now, not good) |
IF you eventually lower it, don't cut the original springs. That's a half-ass job that does harm the safety.
Does it have A-arms or what? My Macpherson struts are adjustable, I could return it to the lowest [or stock] setting at any time.
1 Attachment(s)
aand it's running on the road. :turtle:
thermostat changed and my buddy got the ignition electrics fixed. Also the horns and radio, some soldering must be done to the cluster so the lights will work and change sensor for water temp :thumbup: already put 500km on it already and it seems to run well. MPG will be calculated soon. gearbox is a bit hard-shifted, but it's gotta hold until i get the 2.5TDI installed, then i'll get a M90 gearbox |
and now the temp sensor works!
radio too. Just some smoothing out soldering faults in the gauge cluster. mileage doesn't seem ultra bad, judging from the fuel meter. It also seems my car has a limited slip differential. |
Mileage seems to be something like 24Mpg, LOL.
Albeit i've pretty much floored it all the time :/ gotta lure out the fixes |
Once had a land cruiser bj75, it gulped 12L/100km even if you'd drop it from an airplane :p |
it also seems it has the short rear diff
It does seem quite thirsty for a Diesel.
https://i.pinimg.com/474x/c8/64/46/c...-jeep-mods.jpg Presumably the side-facing ones usually found in the wheelchair spot in urban transit buses might not be accepted by the office of vehicle registry there, so maybe something similar to the 3rd-row seating of the 1st-gen Fiat Doblò could be used. |
Got nice mileage by driving calmly on the highway in the cold finnish winter :O driving highway at 50mph/80kmh because of winter speed limit. i am already VERY satisfied with current mileage. Can't wait how well it'll be
our yearly car tax has been "temporary" for 60 years now! :D |
How are they about paint on the inside of the windows?
http://cdn.automovelbrasil.com/800/2...60e0243317.jpg http://cdn.automovelbrasil.com/800/2...738e663554.jpg Now, would that approach be legal? |
a van here can have glass sides. but a normal car-based van just cannot have more than 1 row of seats. For example, toyota Hi-aces are 3-seaters but classify as a van
Wagon got new springs, Awesome!
also, new brake parts. the exhaust is being worked on But it has it's small dings here and there |
My side-exit exhaust went through inspection every time without question, well worth doing if you're thinking about it. Saw about 0.3LHK improvement in consumption at the same time - plus it sounded rude!
If you've got a turbo you want to hear it right? |
straigt to rear, actually
1 Attachment(s)
i also drove 1000km on monday to Helsinki and back. :turtle:
I don't like driving in big cities. also, the trams are a headache, we don't have them elsewhere :D was a bit hard to remember from my driver's ED :eek: |
Same here, that's why i live in a small town :D
How was your consumption on that longer trip? |
average consumption has been about 7,4-7,5.
when the fuel light goes on, i refuel it with 20€ and drive 'til the light goes on again got original volvo Thule roof rails, not good for consumption but oh well |
TDI swap getting closer, my friend is rewelding a oil pan to fit the TDI and the electrics have been sorted
