EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   New Chevy Volt & Template....Verrrrrry Interesting (https://ecomodder.com/forum/showthread.php/new-chevy-volt-template-verrrrrry-interesting-30857.html)
ChazInMT 01-12-2015 11:20 AM
Higher Res Version Here
http://i60.tinypic.com/2vmght3.jpg
Saw this on Autoblog and thought it was worth posting.
Just sort of another vote in favor of the Aero Streamlining Template Version 2 having some credibility as I see it.
I don't know what the Cd is on this car. The template goes to 35% or so to the back of the lip on the car here.
NeilBlanchard 01-12-2015 01:33 PM
They are claiming a ~35% increase in EV range, with a 8% increase in the battery pack capacity, and ~200-242 pound lower weight, so that point to a ~20-25% improvement in Cd?
MetroMPG 01-12-2015 02:01 PM
They may be using more of the battery pack capacity too - they had large buffers to play with, based on data they're getting from the fleet.
Also reported: the electric drivetrain itself is supposedly more efficient.
dirtydave 01-12-2015 03:46 PM
I knew V2 would be better.
aerohead 01-12-2015 06:25 PM
roofline
Let's see if the press attacks it.In the past they've really beat up on this roofline with respect to rear headroom and outward vision.
When GM did the first :)Citation concept car they eluded to internal criteria for outward visibilty as justification for the faster contour.This new roof would eclipse that thinking.
Interesting.Thanks!
PS,the Volt has an interesting sideview mirror.The stalk is more streamlined and the main body of the housing is moved well outboard,like Stingray.
gone-ot 01-12-2015 07:29 PM
Sorta like how rear-mounted jet engines are always spaced out/away from the airflow along the fuselage.
Vman455 01-12-2015 08:19 PM
I'm very curious about this as well, but have not seen it mentioned in any article on the car so far. Unfortunately, I think if it was anywhere close to Tesla territory, GM would be trumpeting that fact in the press releases, which leads me to believe they haven't markedly improved it.
Here's a screen cap from their promotional video on the new Volt, with some smoke traces:
http://i1047.photobucket.com/albums/...psb45c472c.jpg
Vman455 01-12-2015 08:30 PM
And here's the GM press release dealing with "aerodynamics and aesthetics," including this little nugget: "While a longer, tapered tail generally means better aero performance, it can hamper cargo room and look slightly out of proportion."
That, ladies and gentlemen, is why we can't have nice things.
MobilOne 01-13-2015 02:50 AM
Nice looking car!
sendler 01-13-2015 06:15 AM
It will be interesting to see how much Chevy improved the efficiency of the new Volt when running on gas. The previous car was a complete disappointment averaging only 37 mpgUS.
