new to the forum
Not exactly new, but been a long time lurker. This forum says I need 10 posts to be able to send private messages.. This is number 6.
I am active on several other forums as well. GTD Diesel, GTD VW Diesel - Index Biodiesel infopop, Forums I own a 1980 rabbit diesel. I am trying to get the highest mpg as possible, without adding a boat tail, because I pull a trailer behind the car moving stuff around very often. My goal is to get into ~60mpg area. |
What fuel mileage are you getting now ? 60mpg is what many would like to get ;) |
I have a 1.5L diesel, I get 38mpg around town and highway. I got 32mpg pulling a trailer with a motorcycle on it at 65mph in 30*F
The 1.5L is pretty well worn out. By manufacturer specifications it is no longer a serviceable engine and needs replacement. mfg wear limit for compression 398psi or 40psi difference between cylinders. I am at 310, 350, 370, 370. I have a 1.9TD from a 95 jetta going in it this summer. Just making sure its bottom end is nice and tight so it can provide me some good service. |
The TDI would be overkill for the light Rabbit :) Good luck with re-engining it ! |
the 75HP IDI motor
Adding a hitch to my Firefly is on the to do list for that reason (and also so I can occasionally tow a light trailer). |
