New to the Forum, and I have an idea
I'm new to this forum and I've got an idea for a project. let me know what you guys think.
I'm an engineering student and did a basic spreadsheet calculating fuel mieage using drag and engine efficiency, BTU in a gallon of fuel, etc. It gave me posssible values of 55 mpg for a crx and 55 for a vw diesel rabbit. I did a sheet for a vw 1.6 diesel swapped into a crx. Really simple and cheap. The spreadsheet spit out 80 mpg for the diesel crx at 55 mph on a level road. From your experiences, do you guys think this project would be worth completing once I graduate? I can't find anything about a swap like this except a guy on youtube who never showed the thing completed. |
There are much easier ways to get an 80 mpg car. However, it is still quite doable.
What we think doesn't matter. After doing the research; if you think it's worth doing, then go for it. But have fun doing it!
I think the only thing better would be a VW TDI in a Prius, as a hybrid.
jdu3 -
I think you're on the right track. Here is a Saturn TDI example : http://ecomodder.com/forum/showthrea...tdi-14758.html CarloSW2 |
Thanks folks for the greetings and advice. I'll be lurking in the forums a little but probably won't post much til I m ready to work on something.
BTW, I am right now driving an 82 toyota 2wd truck with 44 PSI in the tires getting around 32 mpg. |
I was thinking the same thing about the swap. What other lighter smaller cars could you swap a TDI motor into? 80 mpg would be nice plus do some eco mods mentioned in here to get 100? Just found this thread about the swap http://forums.vwvortex.com/showthrea...into-honda-crx |
Now the 1.2 TDI in a Gen I Insight would be killer. Basically a Lupo that is legal here in the US. Darn EPA / NHTSB :( :mad: |
I would suggest you mod it to allow engine off coasting while you are at it. A complementary electric oil pump for the turbo(if it has one), a manual steering rack(maybe the CRX already has this) and a brake booster that works with the engine off should do it.
