New full underbelly panel for my 93 festiva
Finished it this evening when I got home.
Front http://i714.photobucket.com/albums/w...psd2afbc26.jpg Front underside http://i714.photobucket.com/albums/w...ps10e283b7.jpg Drivers side under door http://i714.photobucket.com/albums/w...ps5ada9432.jpg Rear http://i714.photobucket.com/albums/w...psb69a69d1.jpg Materials used. 1 1/2 pieces of coroplast ($17) 1" tornilo screws (1box $4) 1" diameter washers (on hand) 20' of flooring metal ( had it on hand) 10' of L shaped aluminum track (had it on hand) Card board used to pattern (leftover from a recent tub install) Utility knife (I use this for work so no cost to me here) Time spent= 8 hours Total money invested= $21.00 Miles to recoup investment= ? Upon taking it out for its first test drive it was awesome how little throttle it needed to maintain 60+ mph. It feels similar to the throttle I was using at 57 before just as a guess. Hopefully this will put me on my way to reaching that 60+mpg tank that has so narrowly eluded me thus far. |
I like the sound of almost no throttle to keep it at 60 mph :)
Sweet!
Nice work, but the middle of it looks a bit loose. THe festiva isn't very aerodynamic to begin with, but the low throttle at 60mph is encouraging. Keep up the good work.
Gil |
looks good, nice job. More Pics needed! is that looking at the front?
Updated with more pics :) |
more pics
I see a cutout for the exhaust pipe, but how close does it come to the muffler itself?
i'll bet with the addition of a Kammback you'll easily be right there!! :{)
This is the closest I've gotten to doing a Kammback :) A little cleaner separation and I still have full visibility out my rear allowing for little interior side mirrors. If I do anything else it will be a full boat tail! |
Nice work! Aren't you worried about the exhaust pipe melting the plastic?
My coroplast under panelling gets within 2 inches of my muffler and I have had no problems with plastic melting in 9 years and almost 200,000 miles of driving. Coroplast is made of polypropylene, which has a melting point of 266 degrees F.
-What exact type of fiberglass are you using? -Is it going to retain moisture? -Pics? I ask because you might find some issues with it retaining a lot of moisture and causing advanced corrosion on your exhaust piping (and possibly the body of the vehicle itself). This will also keep a lot more heat on your exhaust piping, which has it's ups and downs (though I'm not really clear on the downs, honestly. A bit of research might be needed here). Quote:
(lol, reminds me of this..) http://t.qkme.me/3lcd.jpg |
Nice one man, hope you don't mind me copying you again!
Hopefully I'll get time to do mine this weekend. I can already feel a small difference in the length of coast just from the wheel skirts, so I think with a full belly pan I might see a big increase in the "glides" I have everything but the plastic, and I can get pallet-sized heavy duty plastic sheets for 2 bucks each, so I'll be another 6 bucks into modding at that point. Planning on doing a 3-piece pan, with a couple of inches of overlap and a small gap for fluid drain at each section (in case I hit high water, my area floods alot). I'll post pics of the finished product. I posted the wheel skirt addition here somewhere the other day |
https://encrypted-tbn0.gstatic.com/i...Rlmr71HZO2LnDV |
