Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-21-2009, 01:45 AM   #1 (permalink)
recycle old battery lawnmower
hey so i picked up one of these that was on the curb of my neighbors with a free sign:
Black & Decker Power Tools
Battery - 24 Volt, 17-amp hour, sealed lead/acid type deep discharge battery
Motor - 24 Volt, 1200 watt permanent magnet electric motor
Cutting Path - 19 "
Height Adjustment - 1 Touch
Weight - 76 lbs
Cutting Heights - 1 1/2-3 1/2 "
Ideal Property Size - up to 1/3 Acre
(that is optimistic in my experience)
Mulching Capability - YES
Charge Time at 60% - 4 hrs
Charge Time at 100% - 10 hrs
it does not have a charger and i was wondering if anyone had any ideas on what i can do with the parts (motor and 30amp controller) I don't want to buy a charger because i already have a plugin plus 2 gas mowers. I was thinking of a electric bike setup?? Could i use the motor in a wind turbine??? please give me some ideas
Old 09-21-2009, 11:45 AM   #2 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Am I correct in thinking that the controller only has one speed, full throttle?
Ask your neighbor if he has the charger for it.
Old 09-21-2009, 01:58 PM   #3 (permalink)
I think that's the same model I have. The "24 volt battery" is actually two 12 volt batteries wired together, and yes, the controller is just on-off, no speed control.
I like mine just fine: even though my property size is much more than 1/3 acre, not that much of it is lawn. It's nice not to have to mess with pull starting or gas cans - I've probably saved half the price just from the neighbors' kids not being able to "borrow" gas from me.
Old 09-21-2009, 03:56 PM   #4 (permalink)
well i hooked up the charger to the battery and the charger showed 0 amps charging so im guessing the batteries are fried. Could i use the motor for a wind turbine or micro hydro project?
Old 09-21-2009, 04:13 PM   #5 (permalink)
It would be plenty of power for an electric bicycle. You need to find the right gearing so the motor doesn't overheat.
You could keep the existing controller as long as you pedal up to a decent speed before you engage the warp drive.
Don
Old 09-21-2009, 10:48 PM   #6 (permalink)
I'd pull the batteries out and try them individually on a regular car charger.
Old 09-21-2009, 11:55 PM   #7 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
@Don: Warp drive, indeed. That's six times the horsepower that I cruise at on my bike, and with no throttle?
As for the small wind idea, well, you have a 1.2kW electric motor. That would be one component in a very small wind turbine, on the scale of the "rooftop alternator" style ones that you can read about on Instructables etc. Economics and physics favor very large turbines, which is fine if you have a few million dollars to spend on one, and you needed to power a neighborhood.
I'd strap a few junkyard batteries to it and make a lawn mower out of it, even if that means you sell one of your other mowers.
Old 02-22-2010, 01:41 PM   #8 (permalink)
How about solar panel on it
Old 03-09-2010, 10:08 AM   #9 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
That bike would technically be illegal, but I doubt anyone would ask about it. Use the Open Revolt controller. Throwing a couple solar panels on the bike would be way cool.
~Jimbo
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
LiFePo4 battery supplier ken102282 For Sale 25 04-24-2015 10:38 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Solar charging two 12 volt batteries (parallel)... SKIN Off-Topic Tech 5 09-04-2009 03:58 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
