Old 08-18-2019, 12:27 AM   #1 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
1995 Buick Roadmaster won’t shift to park
My uncles 95 Roadmaster when shifted to park rolls like it’s in neutral
Reverse is in the wrong spot and easy to slide past.
Any ideas how to fix this quickly?
It’s like everything is shifted over a little on the gear select
Old 08-18-2019, 12:53 AM   #2 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
It has a cable shifter, check at the transmission for a loose arm where the cable connects on the driver’s side about halfway back just above the pan. It could be a bad cable or the shifter on the column may be worn out it is 24 years old now. If everything looks good on the outside, after making sure the car will not run over you disconnect the cable at the transmission and shift it by hand and see how it feels. There should be 7 detents, p,r,n,od,3,2,1. If you don’t get that something inside may have broken, like putting it in park while still moving tends to bend linkage inside.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
