New Member w/ CRX HF
Hi there,
Been driving my CRX HF for about 10,000miles and love the 50+ MPG's Thinking about swapping a d15z1 motor to get some much needed HP, A/C and maybe some more MPG's. |
Picture of my last two cars
http://www.cleanmpg.com/photos/data/...ht_and_crx.jpg Left side: my current 2000 Honda Insight. Right side: not mine, but looks like my previous car - a 1988 CRX HF The Insight was an extreme makeover of the CRX HF that replaced aluminum with steel, and 1.5 ICE with a 995cc hybrid engine. It's going to be hard to get more power AND increase the mpgs, unless you are going to add a turbo or maybe do an engine transplant and replace the OEM with a TDI. |
You think so? I've read of multiple people who have cone this swap. Everyone who has actually done it seems to have picked up at least a few MPG's.
The car that the motor came out of is rated at 50 mpg on the highway. And fuel economy.gov seems to be on the conservative side. and the car weighs at least 400lbs more than my HF. |
Another problem is finding a stock CRX HF engine with low miles or a rebuild kit for the motor. Not easily done!
If you'll be doing the entire civic vx swap get ready for some work. It was my first swap ive ever done but then again I did it from a crx dx to a crx vx ;)
It seems like a swap like that takes most people the better part of a year to finish because the d15z1 engine has a lot more wiring to go along with it to make it work right and not everyone finishes the swap, taking a perfectly good CRX HF off the road.
But I do agree with you, you should/could see an increase in mileage, of course one of the guys on here who did that swap and added A/C saw a drastic drop in mileage with the A/C use. |
Sacrifice a all hated dpfi dx :thumbup: like i did :D |
I planned on doing a ODB-0 to ODB-1 patch cable to save myself alot of trouble. I've done swaps before also. The most extensive one is a WRX motor in a '74 Porsche 914 which is still in progress. It has been off the road for 2 years, but not due to the swap (well, not entirely). |
