New nuclear technology
https://oilprice.com/Alternative-Ene...sion-Tech.html |
So, 20 more years.
20 more
The adage used to be: ' it's 30-years away, forever!' :D
Aren't flying cars perpetually x years away? Is there anything else?
Everything. The one I'm most interested in is the fantastic materials carbon nanotube are supposed to deliver. A cure for Covid?
I'd settle for a cure for the common cold. That reminds me, all our problems are supposed to be solved with CRISPR. |
anything else?
Carbon nanotubes will reverse hair loss, cure cancer, shrink your gut, improve eyesight, iron wrinkles, and boost testosterone!
nano
Normally lithium is used to make hydrogen for nuclear fusion. It doesn't leave any radio active byproducts.
The US has plenty of heavy water so we got enough deuterium to last a while if we had nuclear fusion. But a better use of heavy water is breading fissile fuel from depleted uranium or thorium or just using natural uranium, depleted uranium or thorium as reactor fuel. |
Do you want polymetal alloy terminators?
Because that's how you get polymetal alloy terminators. |
