New Prius
1 Attachment(s)
So Wayne at clean mpg posted that the leap from 19 inches to 17 inches for wheels gives a huge benefit on economy. The people at the Prius forum have figured out the smallest wheels you can put on it with brake clearance are 16 inches. How much better fuel economy would you guys could be possible with 16 inches versus the amazing results from the 17 inches?
60 mpg highway rating or 58 mpg at 70 mph is crazy with a 200 hp engine. Toyota engineers are wild |
' how much better '
What aspect ratio on the tires? I have a set of tires on the Golf with 18"rims that are half the diameter of the F250's 16" rims but 1.5 times as wide
same width. 17 inch prius is apparently 6 inches lower too. slightly more aero rims also |
Surely? "I have a set of tires on the Golf with 18"rims that are half the diameter of the F250's 16" rims tires but 1.5 times as wide"
"17 inch prius is apparently 6 inches lower too" Five inch top chop? :cool: |
I’m just trying to see if it’s worth downsizing to 16 inch wheels and make custom fully closed wheel covers when I get the new Prius. Air suspension to lower even more is also planned
Used to be 15" wheels were huge, and most cars were running 13 or 14" What happened? My truck runs 17".
I stand by my statement. Could diagram the logic but might make sense to only me. Thanks for the minor correction.
Did a search and found this. Size Matters – Why Large Rim Diameter Tires are Here to Stay https://www.tirereview.com/large-rim-diameters-tires/ Quote:
https://mechanics.stackexchange.com/...over-the-years Quote:
https://carfromjapan.com/article/ind...wheels-in-car/ Do smaller diameter tires on cars give a more comfortable ride than larger diameter tires? If so, why did they make wagon wheels so large, if not to make the bumps less harsh? https://www.quora.com/Do-smaller-dia...mps-less-harsh Do bigger wheels mean better comfort Post #28 https://www.team-bhp.com/forum/india...comfort-2.html Quote:
