EcoModder.com
-   -   New tires - size up! (https://ecomodder.com/forum/showthread.php/new-tires-size-up-18379.html)
mcrews 08-03-2011 05:50 PM
I went into to RADIAL TIRES of SACRAMENTO this morning after researching sizes this past weekend.
Background:
THe 02 Q45 Sport came from the factory w/245/45/18 (26.5 inch diameter)on 18x7.5 alloy rims.
At 60k miles I went to a 255/45/18 (27.0" diameter)
The base of the Strut tower on the front is the limiting factor to how tall a tire can be without using 30mm spacers( BAD:eek:)
http://i678.photobucket.com/albums/v...5clearance.jpg
We tried a 245/50/18 and there is an 1/8 inch gap!!!
THe diameter is 27.7 inches.
The tire weighs 31lb and the current size weighs 30 lbs.
They ordered them today and will install tomorrow.
320touring 08-03-2011 06:41 PM
You could cut off the spring platform and fit threaded sleeves so you can fit 2.5" diameter springs:D
mcrews 08-04-2011 03:47 PM
Got the tires on today.
new 245/50/18 27.7" dia. at 55mph 1625rpms
old 255/45/18 27.0 dia at 55 mph 1725rpms
will do mpg runs in a day or so.
mcrews 09-05-2011 11:30 PM
as you can see there is no more room!!!
talkhttp://i678.photobucket.com/albums/v...PG/tiregap.jpg about cutting it close!!!
gone-ot 09-06-2011 12:09 AM
...do you think there's "contact" when driving at high speeds and centrifugal forces are attempting to "enlarge" the wheel diameter?
Vekke 09-06-2011 10:08 AM
If you install coilover suspension you dont need so big spacers to get more room. Or change you ET on your wheels.
mcrews 09-15-2011 02:46 PM
Well, it's been a month. Had a round trip from Sacramento to LA.....450 miles each way.
No problem with any rubbing.
I had some obdII codes that I had to resolve. And am still addressing some ecu issues pior to my TTT (trip to texas) on Oct 12.
But I just ran a brief highway run.
At 63mph 1775rpms got 30.9mpg (didnot have the grill block or the front underbelly panel in place)
epa is 22mpg highway.
gone-ot 09-15-2011 06:20 PM
...cars need an "electronic" wheel diameter compensation "box" to allow for use of different diameter wheels & tires!
mcrews 09-16-2011 12:38 AM
somebody was posting that in europe it's illegal to go up or down in size........
I run a garmin gps on the dash right above the scangauge, so it gives the correct speed.
That way I don't tie up one of the 4 displays on the scangauge.
mcrews 09-16-2011 12:40 AM
Why would I want to ruin the electronic suspenion........:confused:
